"The BIG BOV thread" (Where all bov question threads get merged) - Page 102
This is a discussion on "The BIG BOV thread" (Where all bov question threads get merged) within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; how do i install the blow off valve ther are springs with it. is there anywhere where i can get ...
  1. #1516
    Mar 2002
    Chicago
    install?????
    how do i install the blow off valve ther are springs with it. is there anywhere where i can get instructions for this. i didnt get any
  3. #1517
    Moderator aussieinstlouis's Avatar
    Jun 2002
    S34 47.322 E138 29.131 (WGS84)
    there is already a spring in it. The others are different tension if you need them for your set-up.
    Install the BOV and see.
    IF you need to change the spring - undo the hex screws and the thing pops apart (just hold it all together as you release the tension on the spring - it is a very simple mechanism - you don't really need instructions.
    If you are worried - call George at Forge Motorsports in Florida - he gives great support of Forge gear.
    Cheers,
    Andrew
  4. #1518
    Mar 2002
    Chicago
    instructions on blow off valve
    where can i find instructions to install a forge blow off valve. i didnt get any. i want to do this the right way . please! and thank you!
  6. #1519
    Jun 2002
    Check the other thread - I have put some details there.
  7. #1520
    cnk
    cnk is offline
    NJ
    1. pop hood
    2. undo 2 12mm bolts on stock BOV
    3. pull vacuum line off stock BOV
    4. lift up stock BOV and squeeze clip to remove intake return hose
    5. reassemble in reverse order
    Calvin
  8. #1521
    Moderator MidKnight's Avatar
    Oct 2002
    Bergen, NJ
    Question for Forge BOV Owners
    I just installed my Forge BOV. IT has a nice sound most of the time, but sometimes I only get a flutter instead of the whoosh... Is this normal? Or do I need to install the stiffer spring? I usually get the flutter when I'm not going from WOT. Also sometimes I get the flutter right before I get the whoosh. Again, is this normal?
    -MK
    '03 WRX
    '01 2.5RS
    MODS | PICS | Dyno
    "Stuff sold by the gram is always going to be more exciting than stuff sold by the pound." - Jeremy Clarkson
  9. #1522
    Registered User is2scooby's Avatar
    Jun 2002
    Honolulu, HI
    It sounds like you may need to try a SOFTER spring...
    Aloha, Richard...
    Retired Moderator
    TXS Stage 4 UTEC + TMIC + JoeP
    12.75 @ 105.67mph - 1.74 60'
  10. #1523
    Nov 2002
    My gfb bov does that too, usually when i shift at 3k with light boost. If i shift at 4k, the flutter sound is barely there, if not at all.. Try to shifter around 4-4.3k...
    2003 WRX 5spd Sedan
    ~Stage 4+ 20g~
  11. #1524
    Registered User NJwrbT-WRX's Avatar
    Apr 2002
    One Square Mile, NJ
    I get the same thing. I have not tried the other springs yet (I have all three) and I will when I get my car back. I agree with Richard, you probably need a softer spring....but I think a lot of people have similar situations with both Forge and other BOVs.
    -joe
    '02 WRB Sedan
    Removed silencer w/ Akimoto Velocity Stack, Blitz Dual TT, Autospeed Prototype Up-pipe w/ Flex-joint, Autospeed Crank Pulley, Autospeed OEM Dead Pedal, Samco IC Hoses, Axxis Pads, Goodridge Lines, Neo Synth Brake Fluid, Speedbleeders, Eibach Pro-Kit, Perrin Endlinks and Rear Sway, 17" Sub Zeros w/ 225/45 ES100s, Crucial Racing Thermostat and 1.4bar Radiator Cap, Autometer Sport-Comp Oil Pressure, EGT, and Voltmeter on the A-Pillar, STI Hoodscoop.
  12. #1525
    Registered User ***biGRed***'s Avatar
    Oct 2002
    mine starts to flutter now too after i just installed my intake last weekend. before it had a nice pshhhhh sound but now it sounds like the bov from the supra on best motoring 5.
  13. #1526
    Oct 2002
    Bergen, NJ
    Ok, I'm gonna try the softer spring within the next few days. I guess that does make sense since the softer spring would allow it to open with less pressure (ie when I get the fluttering). Thanks for the help guys. I'll report back when I make the change.
    -MK
    '03 WRX
    '01 2.5RS
    MODS | PICS | Dyno
  14. #1527
    Registered User Nexus6's Avatar
    Jun 2002
    O.C., Ca
    that simple, basically bolt on replacement...
    La Fee Verte
    Subaru 2002 Impreza WRX Sedan
  15. #1528
    Registered User Jack's Avatar
    Mar 2003
    North New Jersey, School at Susquehanna University in Pennsylvania (Rt 287, Rt 78, Rt 22, Rt 80)
    Thumbs up
    Thank You Matt, really helps.
    Tom
    -My name is Tom not Jack
    Check profile for mods
    "I wanted to put a bullet between the eyes of every panda that wouldn't screw to save its species" Fight Club
  16. #1529
    Apr 2003
    Pennsylvania
    Exclamation Subaru BOV install
    I just got my Subaru BOV and i was wondering if it is difficult to install, or is there any link to a HOW TO install this piece. Any help would be greatly appreciated.
    Tim
    2002 Aspen White Impreza WRX.
    AEM Short Ram Intake, APEXi Turbo Timer, STI Strut Tower Bars F&R, Tien Springs , Tokico Premium Performance Shocks, Rota Torque 17x 8", Toyo Proxes, STI V1 Front Lip
    JDM STi Hoodscoop, Zerosports Carbon Fiber Risers
  17. #1530
    Registered User racerWRX's Avatar
    Jun 2002
    steeltown
    im confused... the wrx already has a recirc bov....and subaru makes a factory one???? which bov are you talking about ????
    have you ever been 4 bagged ???
