hey everyone another turbo question
Results 1 to 12 of 12
This is a discussion on hey everyone another turbo question within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; for my next upgrade i am thinking about a sti turbo. i want to start taking step by step before ...
    Jan 2007
    ambler
    for my next upgrade i am thinking about a sti turbo. i want to start taking step by step before i hit my goal for 300 whp+. i am thinking about buying a stock sti turbo which i believe is called the vf-39. i was wondering how much can i look to get on my wrx with a CP. i am also wondering can i go to a stage 3 with that turbo? since it is an upgraded turbo from the wrx Thanks in advance.
    Registered User bcyb1029's Avatar
    Feb 2006
    Chicago
    If you are trying to do this cheap you will need pinks, fuel pump, sti tmic, tbe, up-pipe, access port or open ecu maps that has good OTS map, and the Vf39. This is what you will hae to buy to at least run the turbo safely. You should probably make 250-260 with the OTS map and a bit more with a protune with the mods above. Do you have any mods?
    Tuned by Jorge at P&L, 240.83whp 239.60wtq at 14.8psi on 2.0L with stock td04 (But doesn't run)
    Jan 2007
    ambler
    hey yea i currently have a stage 1 cobbaccessport. when you said 230 to 250 i hope you were talking about whp.
    Feb 2006
    Chicago
    ^I said 250-260 but yes I am talking of whp. This is on a conservative OTS map, a protune and some other mods such as a turbo inlet, ram air intake, and bigger tmic or even a fmic if you plan on going bigger later, you can push 270whp-280whp.
    Dec 2005
    Puerto Rico
    I went w/VF-34 and got these results.
    STi 2006, RED, 480whp 469wtq @28.9ps.
    Registered User drummerboy's Avatar
    Aug 2005
    If you have an 06/07 WRX its not a "must" to get an up-pipe with it being catless already, and the injectors will work fine with the vf-39 as it is high-flowing already.
    If it isn't, forget what i said
    2006 WRX - World Rally Blue
    Feb 2006
    Chicago
    Your #'s should come with a disclaimer on the bottom like the diet pill commercials, those #'s are next to impossible to get in the states.
    Oct 2005
    long island
    Quote Originally Posted by RickWRX02 View Post
    Yeah those numbers seem screwy
    06-wrx: stage 2 and loving every minute of it!
    Feb 2007
    NY
    Perfect example: My Signature.
    Jan 2007
    Dirtee Jersee
    yo Rick how are you running so much power and haven't made your engine go KABLOOEY yet? And how hasn't your transmission gone GGGGRRRRPPFFFTTTTTkkkkunkkk yet?
    I'd be afraid to drive my car with that much power and stock internals.
    Moderator
    Jul 2003
    Maryland
    Quote Originally Posted by Blup View Post
    Very possible it's a race gas tune...he has meth...and it could be a high reading dyno. I wouldnt call his resulsts "normal" by any means.
    Dec 2005
    Puerto Rico
    My car is very well taken care of. Its fast as hell and yes my tranny will give up eventually. And the numbers are so real. I posted a thread Monday I believe w/my spec and yes I run w/meth. Thread:
    My WRX 02 (VF-34) Dyno Numbers & Pic's
