Ninfourteener's Progress Thread + Pics - Page 6
Page 6 of 59 FirstFirst 1234567891011121314151656 ... LastLast
Results 76 to 90 of 885
This is a discussion on Ninfourteener's Progress Thread + Pics within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Your engine's so clean I love the sucking sound of them intakes. Hope it helps performance. Looks great though!...
  1. #76
    Jan 2007
    Dirtee Jersee
  3. #77
    "Supreme Subaphile Extraordinairre" ninefourteener's Avatar
    Mar 2006
    SLC area
    So last night, I got my Supertones in. I feel kinda "ricey" because they aren't wired in yet (didn't have time on a school night)... but I was able to get them mounted.
    I REALLY hate all the 06's I've seen with the Supertones mounted right next to eachother, both visible through the center grill. I think it makes the car look cross-eyed.
    I like the way the 04-05 WRX's had them separated further apart.
    So.... I tore the grills off, and looked for a suitable mounting point... and found a great location.... the support bolts for the radiator.
    I did have to remove the back-plates to my side grills to fit the Supertones in there, but it didn't affect the structural integrity of the grills... and I'm quite pleased with how they look:
    2006 Subaru WRX-Thread: http://www.clubwrx.net/forums/engine-modifications/165158-ninfourteeners-progress-thread-pics.html
    1978 Subaru BRAT-Thread: http://www.clubwrx.net/forums/engine...ss-thread.html
    2007 Subaru B9Tribeca Ltd (PSM)........1994 Subaru SVX LSi(SOLD)
    WRX 12 sec drag (vs. late model Camaro SS):http://www.youtube.com/watch?v=lw0vWdD2cjU
    WRX track racing (catching a stg.2 WRX): http://www.youtube.com/watch?v=mELeSD1Mi08
    Co-Founder/retired Admin-www.slcsubaru.com
  4. #78
    Jan 2007
    Dirtee Jersee
    dude you're raping photobucket's bandwidth. You gotta find new hosting.
    I've got a website i might be able to set you up with an ftp account for, just cause i love your car so much
  6. #79
    Mar 2006
    SLC area
    Quote Originally Posted by Blup View Post
    I appreciate it.. Thanks!!
    I have so much in photobucket... it was easier to just upgrade for $25.00
    2006 Subaru WRX-Thread: http://www.clubwrx.net/forums/showthread.php?t=165158
  7. #80
    Jan 2007
    Dirtee Jersee
    I don't see any pics i just say "exceeded bandwidth".
    I've got 3500 GB per month bandwidth that I won't even begin to come close to using. Just let me know if you ever need hosting.
  8. #81
    Moderator Donkey's Avatar
    Da boonies,Va
    Quote Originally Posted by ninefourteener View Post
    I've just heard about 1000 horror stories of cheap BOVs causing backfiring, poor idle, stalling, etc.
    But I could never actually "personally" provide my experiences.
    But, I figured, to find out for myself, I bought what I believe is one of the best, most reliable BOVs out there... just to see.
    Turns out.. GFB makes a great product... no adverse effects at all. And I was surprised, there is actually a small performance gain.
    Do you have any before and after logs or data that can confirm this or are you just going by the old butt dyno?It's generally the 100% atmoshereic BOV's that cause the idling/stalling issues.
    2002 FORESTER S
    1998 FORESTER S
  9. #82
    Mar 2006
    SLC area
    No, no real "data" to prove my claims... just the butt-dyno.
    I did notice my boost gauge held steady a little longer, and tapered down a little later.
    Not much at all.... maybe a couple extra HP... hardly worth spending hundreds of dollars on a new recirculating BOV.
    I got mine used for under $100.... thats the only reason I bought it. I figured if it made the car run worse, I could just turn it over on ebay.
    Turns out, the GFB doesn't hurt my car at all... doesn't affect the way it runs (negatively) at all.
    Non-recirculating BOVs are the ones that cause backfiring, stalling, etc. I heard the same thing you did.
  10. #83
    Oct 2007
    Your car looks great man. Like what you have done with everything.
  11. #84
    Da boonies,Va
    Most/some aftermarket BOV's that vent can actually cause you to lose performance if your stocker was working normaly.Most peoples butt dynos are generally out of calibration. Since you have the AP if you have a laptop with a serial port or use a USB/serial adapter,you should be able to download Ecuexplorer (free) and be able to log the car.It's a neat little tool that is a great diagnostic aid and can help you weed through the hype and really see for your self whats happening to your car (if you want).Stuff like watching your IAT's skyrocket at idle,AFR's go whack at w.o.t., and MAF scaling get skewed from using a poorly designed S.R.I. Little info about BOV's http://www.spdusa.com/blow-off_valves.htm Not saying the SPT intake or GFB bov are causing any dramatic problems but thinking your car is running right and knowing your car is running right are two different things.By taking a baseline log before and after installing parts then comparing the two can help spot potential problems or to see if performance has changed.Believe it or not the 06-07 WRX's actually use a slightly larger MAF housing than the 02-05's.This means using an intake designed for an 02-05 on a 06-07 will cause you to run even richer than normal.Not going to hurt the car,but probably not going to help performance.Probably why when you buy the SPT from the dealership and have it installed they reflash the ECU (or are supposed to).Not trying to rain on your parade,just trying to bring some info to light.I really like the route you've gone!Nice stylish outside look.Not the attention screamer look most people seem to like.That grey is such a great color!
    2002 FORESTER S
    1998 FORESTER S
  12. #85
    Mar 2006
    SLC area
    So I was off today, and I met my wife in SLC on her lunchbreak. I stayed for the next 1.5 hours or so, and we decided to go on an expedition to find Cobb Tuning. Turns out it was only about 5 or 6 miles from my wife's job
    Well worth the trip. "Parker".... super-cool guy took me back to see the dyno, gave us a tour of the place, and then just chatted "Subaru" with me for over an hour. I still have plans to get dynotuned.... but I can't decide if I want to do that first, or get some swaybars... same price, but don't have the cash for either right now.
    I did get a free COBB T-shirt too..... cool huh?
    Sorry the pics are low quality... cameraphone... it's all I had with me.
    The Facility:
    Inside the building/waiting room:
    My sexy wife (more specifically, her butt):
    COBB CARS!!!!!:
    A couple shots of me and the Time Attack STI:
    Even got one of the wife's Maxda3 and the Cobb Mazdaspeed3:
  13. #86
    Jun 2007
    Great Salt City of Utah
    Nice pics is your car in Utah
  14. #87
    Jan 2007
    Dirtee Jersee
    wow man that's awesome. the display of exhaust pipes is so cool lol. And +1 to your wife man. Lucky guy! Cute kid too! Sweet car! Damn man! Wife + kid + STi + cobb facility??? Jeeeez. that's a lot of peoples dreams lol.
  15. #88
    Registered User Lipster's Avatar
    Jul 2004
    Southern PA
    Bov`
    Gotta say, I found a WorxTuning DS2 CHEAP... adjustable recirc/atmosphere BOV.
    I have it MAYBE 30% vent to atmosphere and I dont have a problem either with stumbling or backfiring. ANd I agree... I notice that my shifts are cleaner -- my wife and I notice that the spoolup time is noticably QUICKER with this BOV. It's a bigger valve so it can move pressure/air more quickly which I would assume less backpressure on your turbo keeping it spinning...
    Hawkeye - 808
    2006 WRB Wagon
    mod list http://www.clubwrx.net/forums/2188188-post359.html - hopefully.
  16. #89
    Jul 2007
    can you show me how you did your oil pressure gauge. i have an autometer oil pressure electric gauge and ive been searching for so long. i saw you have a wrx 06-07 model(not sti) and saw you installed the oil pressure gauge. can you show me
  17. #90
    Mar 2006
    SLC area
    Quote Originally Posted by sheckephano View Post
    You have 3 options:
    1) Underneath the intercooler,a brass, quarter-sized fitting, with a hex shape sunken head.... EXTREMELY difficult to get to - not recommended
    2) an oil filter adapter plate - I've used 2 of them, Glow**** doesn't fit at all, greddy started leaking in under a month - not recommended.
    3) The original oil sending unit, located right behind the alternator, slightly to the passenger side. Remove it and install the OP gauge. You will need to contact Autometer and get the adapter # (I forgot the #)... it's about $15.00, and any auto parts store can have it to you in 2 days.
    NOTE: I did not get a CEL when I removed the original OP sender, but I'm also using a cobb accessport... I don't know if you will if you're not using an EM
    Regardless, option 3 is your best, safest bet.
