Ninfourteener's Progress Thread + Pics - Page 43
Page 43 of 59 FirstFirst ... 333435363738394041424344454647484950515253 ... LastLast
Results 631 to 645 of 885
This is a discussion on Ninfourteener's Progress Thread + Pics within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Ok.... Its just about midnight...... and I've been working on this thing for 2 days..... but all that is left ...
  1. #631
    "Supreme Subaphile Extraordinairre" ninefourteener's Avatar
    Mar 2006
    SLC area
    Ok.... Its just about midnight...... and I've been working on this thing for 2 days..... but all that is left is the alignment.
    Got the rear done first, mostly yesterday.....
    The trailing arms/rear suspension
    Check out the wheel gap.... with the car JACKED UP:
    Then I didn't know exactly where to put the front today when I started on it..... so I dropped them pretty far down.
    Yea..... oops...... not looking to go "hellaflush" - LOL
    I took pictures because I thought it was funny Although I'm sure there's a few folks that think I should have left it like this. I'm sure it's "dope" or "phat" or "tyte" or "sick", or "epic" or something - LOL
    YIKES!!!!!!!!!!!
    So..... I raised it up a bit..... just under an inch.... which gives it a much nicer stance..... and levels out the A-arms as well.
    So...... I'm tired
    I took one last pic....... I jacked up the car right behind the front wheel.... only a little over an inch.
    Check out the REAR wheel in the pic.
    THAT.... is a suspension
    2006 Subaru WRX-Thread: http://www.clubwrx.net/forums/engine-modifications/165158-ninfourteeners-progress-thread-pics.html
    1978 Subaru BRAT-Thread: http://www.clubwrx.net/forums/engine...ss-thread.html
    2007 Subaru B9Tribeca Ltd (PSM)........1994 Subaru SVX LSi(SOLD)
    WRX 12 sec drag (vs. late model Camaro SS):http://www.youtube.com/watch?v=lw0vWdD2cjU
    WRX track racing (catching a stg.2 WRX): http://www.youtube.com/watch?v=mELeSD1Mi08
    Co-Founder/retired Admin-www.slcsubaru.com
  3. #632
    Mar 2006
    SLC area
    Updated Mod list: (new stuff is in red)
    EXTERIOR:
    SPT door logos
    slcsubaru.com rear window decals - Azure Blue
    COBB Tuning license plate frames
    07 STI Ltd. Front lip w/ Azure Blue SPT Logo
    Hella Supertones - custom painted black/azure blue
    Custom hand-made rear towhook - powdercoated azure blue
    Spline-drive lugnuts – powdercoated Azure blue
    SUSPENSION MODS:
    Daily Driver Wheels - Rota Formula Mesh 18x8 +48 BRONZE
    Falken Ziex ZE-512 - 235/40/18, 360 treadwear
    Race Wheels - WORK Emotion CR KAI 17x9 +44 BRONZE
    Hoosier A6 AutoX (DOT legal slicks) - 245/40/17, 40 treadwear
    Winter suspension:
    Eibach Pro-kit springs (1.2 front, 0.8 rear)
    Stock struts (-1.0° F camber, -1.5° R camber)
    Summer/Race suspension:
    Buddy Club Racing Spec Damper Coilovers
    F+R Tophats w/ camber adjustments
    8k F springs, 6k R springs
    Inverted, monotube strut design, 15-way adjustable
    SPC F+R camber kit (-2.0° F+R camber - adjustable to -3.8°)
    Full-time modifications
    Cobb 25mm front swaybar + bushings
    Cobb 25mm rear swaybar + bushings
    Cobb rear swaybar adjustable mounts
    Whiteline rear endlinks
    Kartboy front endlinks
    Greddy front Strut tower bar
    Generic rear strut tower bar
    Generic undercarriage A-arm brace
    Kartboy rear subframe lockdown bolt kit
    Subydude single-adjustable short shifter
    Perrin SSK counterweight Shift knob
    Perrin Polyurethane Front shifter bushing
    Kartboy Polyurethane Rear shifter bushing
    AMSOIL synthetic transmission gear oil
    Redline synthetic rear diff gear oil
    BRAKES:
    Rotora front FC4 4-piston Big Brake Kit calipers
    Rotora 13" (330mm) front drilled/slotted rotors
    Brembo factory STI rear calipers
    DBA 2657 STI 12.4" (316mm) rear slotted adapter rotors
    Stoptech steel braided brake lines (4)
    All 4 dust shields removed / drilled out
    ATE Super Blue racing brake fluid
    *** Calipers custom powdercoated Azure Blue with SPT logos
    ENGINE, ECU MANAGEMENT, AND EXHAUST
    COBB AP V1, stage 3 map, VF39, 91 Octane
    IHI VF39 turbo
    NGK Iridium spark plugs
    SPT intake
    SPT intake heat shield
    Walbro 255 lph fuel pump
    Removal of intake silencer and Air intake duct
    Subaru Fender hole plug
    Factory STI Intercooler
    Factory STI Splitter and rubber bellows
    Perrin silicon Y-pipe
    COBB turbo heat shield
    X02 Racing catless 3-inch stainless steel Turboback exhaust
    COBB polyurethane exhaust hangers
    Custom built 3-inch axleback section w/ A-spec muffler
    *** axleback section powdercoated black chrome
    SPT blue billet oil cap
    OPTIMA yellow-top battery
    Custom Billet aluminum battery tie-down
    Mobil 1 5W30 synthetic motor oil
    INTERIOR, STEREO AND GAUGES
    Factory STI front seats, all airbags 100% operational
    Factory STI rear seats
    Autometer C2 mechanical oil pressure, full sweep 0-100
    Autometer C2 mechanical boost/vacuum, full sweep, -30+20
    Autometer C2 electrical Air/Fuel Ratio, full sweep
    Autometer C2 electrical Pyrometer EGT, full sweep 0-2000
    Autometer C2 electrical Voltmeter, full sweep, 0-18 volts
    Autometer C2 Fuel pressure, full sweep, 0-100 psi
    Autometer C2 DPSS stage 2 tachometer/shift light
    Autometer Tach adapter
    SPI intake temp gauge (pre-intercooler)
    SPI intake temp gauge (post-intercooler)
    Custom "stealth switch" to override headlights & dim all gauge lights
    Autometer triple gauge clock replacement pod
    Autometer triple gauge A-pillar pod
    Glow$hit single cup pod (top of steering column)
    Generic dual gauge pod (center console)
    Factory Clock/airbag indicator relocated to lower stereo din
    Pioneer 9800 Bluetooth stereo head unit
    HTC EVO 4G Android smartphone (plays MP3s+talk+GPS voice wirelessly)
    Factory Subaru Subwoofer (installed afterward)
    Rockford Fosgate 6.5” aluminum dual coaxial speakers (front)
    Rockford Fosgate 5.25” aluminum dual coaxial speakers (rear)
    2006 Subaru WRX-Thread: http://www.clubwrx.net/forums/showthread.php?t=165158
  4. #633
    Mar 2006
    SLC area
    So I had it aligned yesterday.... and had the opportunity to drive it a few miles to and from the shop.
    I officially own the most uncomfortable car on the planet - LOL I thought my kidneys were going to explode.
    Perhaps I shouldn't have left the struts on full-hard?? LOL
    Nevertheless, The guy that did the alignment owns an 06 WRX wagon..... that can stand a quarter between the ground and his front lip..... it is THAT low. He also works on another buddy's 06 WRX with over $100K invested into the car.
    He set all 4 corners at zero toe.... and set the camber at negative 2 degrees at all 4 corners. He also centered out the tophats so I have some adjustability, so I "can" go all the way to negative 4 degrees of camber if I wanted to.
    I installed 5mm spacers on all 4 corners before I brought it to him. Those Hoosiers just were not going to fit under there without them. It ended up working out for the best though, because the Alignment is SPOT-ON and the car tracks beautifully.
    So I guess we'll see how I do at the lap battle on October 30th at Miller Motorsports Park!!!
    http://lapbattle.com/Forum/index.php?topic=339.0
    Entry list (I'm # 14):
    http://lapbattle.com/Forum/index.php...sg1132#msg1132
  6. #634
    Mar 2006
    SLC area
    Wish me luck tomorrow!!!
    Miller Motorsports Park outer loop - 3 miles:
    http://www.millermotorsportspark.com...uterCourse.jpg
    I’ve raced the east course a few times (turns 10-23)…. Never run the whole west side of the track though.
    I’ll hit at least 140mph before I have to start braking for turn 1…… Turn 5 is going to take some effort though.. that one scares me.
    And I (and my car) personally know what it is like to “lose it” and slide off the track on turns 16 and 21… those are UGLY.
    Here’s the folks I’m racing against (I’m # 14)… A couple of Lotuses, a couple Porsches, a corvette, GT500, 350Z, M3… lots of other folks out there… and quite a few more Subies as well. I’m only “technically” competing against the AWD cars in race class (I can’t run street class due to my Hoosier tires and lack of a catalytic converter)… but I’m certain I will be comparing my times with everyone. Driver #1 will undoubtedly whoop me… he’s a professional and wins almost every time he participates….. Driver # 27 is a close friend, and very equally matched… so he is the guy I really want to beat.
    I'll see if I can get some pics or video
  7. #635
    Registered User Hold_Fast's Avatar
    Mar 2008
    Philly Burbs
    Good luck man! Set up is looking good. Looking forward to hearing how she feels on the track.
    ~Stan
    '04 WRB WRX Wagon (Build) - Hard Parked, AutoX Toy
    '08 WRX ~ Daily Beaten ~ '86 BMW 325es ~ "The Chump"
    "I was raised knowing there is a replacement for displacement, it's called engineering."
  8. #636
    Palmyra, NJ
    Good luck dude! That track looks insane (and tons of fun obviously!) Keep it fast and keep it safe!
  9. #637
    Registered User Emsbuff124's Avatar
    Mar 2008
    Rockland County N.Y.
    good luck with the race, sorry to hear about the kidneys. do you need the harness bar when your race??? or just a helmet. i was curious to what type of equipment they mandate to run. I know with drag racing the faster the ET the more equipment ie racing straps, cages, and shoots
    i live my life a 1/4 mile at a time
  10. #638
    Registered User Pavia's Avatar
    Dec 2006
    Philly/DE area
    Good luck and keep the shiny side up!
    06 GTO M6 Quicksilver, SLP 455 Bobcat, LS7 Clutch w/ SS line (RPM tune:373rwhp/373rwtq)
    07 WRX TR M5 Garnet Red Pearl w/ Straight PPGs and Cusco front LSD (Agile tune:307whp/343wtq)
  11. #639
    Mar 2006
    SLC area
    Quote Originally Posted by Emsbuff124 View Post
    Thanks all!!!!
    Kidneys are ok.... once I set the coils on soft... although admittedly, even on full soft it's still pretty brutal. I guess it just takes some getting used to. These aren't eBay BC coilovers.... these things are business. Once this race is over, I'm thinking about buying a set of epic springs to replace my eibachs.... and just putting the stock suspension back on. as long as I mark the camber bolts, I can have the coilovers back on and aligned in under 2 hours.
    Racing seats, harnesses, etc are only required if you have a roll cage. I do not. Helmet is (of course) required.
    Battery has to be tied down, insulated, in a box if you don't have a sealed type battery (I have an optima yellow). No cracks in the windshield, no leaks, no bald tires... just a basic safety inspection.
    Of course, you MUST attend the drivers meeting where they lay out all the rules, otherwise they won't let you on the track
    I'm all packed up... looks like its up to 37 cars now... more Porsches and Lotuses.
    Calling for rain at 3pm... which is right when the final (and most important) session starts... hopefully it holds out.... otherwise I guess we'll see how my el-cheapo Falken all-seasons do on the track - LOL
  12. #640
    Mar 2006
    SLC area
    All is well... I had SO much fun. If you haven't participated in road racing or Auto X-ing... it is an absolute blast.
    Long story short.... 10th out of 41 competitors in the 3rd session. My fastest time was a 2:17. The fastest guy out there got a 2:08... and he showed up in a brand new, factory racecar (Lotus two-eleven). I suppose if you can afford to spend $70,000 on a non-street legal racecar from the factory... you deserve to win a few races
    The good news..... is that I think I was the fastest person on the track, that had air conditioning and a rear seat - LOL I think only 3 or 4 of them were even licensed to be driven on the road.
    #1 was the Lotus two-eleven
    #2 was a full-race prepped, gutted, gaged, plexiglass windshield EVO
    #3 - A porsche 911 (not sure of specifics)
    #4 - Fully gutted, caged STI
    #5 - Fully race prepped, and SPONSORED VW GTI
    #6 - Another raced prepped EVO, owned by Solid Autoworks
    #7 - My friend - gutted, caged STI on 10k and 12k coils
    #8 - Honda Civic - CRAZY modded race prepped civic
    #9 - Ford Focus - sponsored, bought new, gutted, never seen a legal road.
    #10 - a daily driven 06 WRX, with A/C and cruise control...... with the child car seat removed before the race
    I think I was 5th in my class.... so I wouldn't have been allowed to compete in the 4th session anyway (only the top 3 per class)... but I'm thinking about all the cars that I beat... the Porsches, the other Lotuses, the Corvette, the other STIs and EVOs, the M-series BMWs, the S2000s... and everyone else..... and I'm pretty happy with that Makes all the work I've done seem worthwhile.
    ..... Now if I just had a "wee" bit more hp....... 20g, 850cc, FMIC...... coming soon I'm actually thinking about welding on a catalytic converter.... buying some Yokohama Advan A048 "street" tires.... and entering (and sandbagging) street class next time Hey.... it IS an actual street car... I drive it every day... would that be dishonest?
    My transponder didn't work in the first session, so I have no times.
    I was 12th in the 2nd session
    http://www.mylaps.com/results/showrun.jsp?id=1741200
    and of course, 10th in the 3rd session:
    http://www.mylaps.com/results/showrun.jsp?id=1741201
    The reason I only did 6 laps instead of 7???? I TORCHED my front brake pads... down to the bare metal. Even if i had placed 3rd in my class... I was done for the day. 18 minutes into session 3..... pedal went to the floor, and all I heard was this excrutiating sound of bare metal.
    I took the pic below.... sent them to Rallysportdirect.... but of course..... no one keeps Rotora pads in stock.....
    I drove home 40+ miles...... without ever touching the brake pedal... I used the tranny to slow me down... and the ebrake to catch me at stoplights - LOL That's how pimp I am - LOL
    I'll post pics as soon as Rallysportdirect or Miller Motorsports Park decide to post them on their websites.
    I'll go ahead and exit with this beautiful photo - LOL Yes, this is the PAD side.... My balls actually hurt when I look at this photo.
  13. #641
    Registered User irvin787878's Avatar
    Jun 2009
    Milesburg / Near State College PA
    wow really sucks about the brakes pads. but i think u did awesome overall.
    HAWK-EYE ALLIANCE #7878
    2007 WRX TR
    My work in progress. http://www.clubwrx.net/forums/off-to...ld-thread.html
  14. #642
    Palmyra, NJ
    ZOMG!!!!!!!!!!!!
    Did you damage your rotors at all???
    And of course congratulations on kicking some ass and repping Subaru!!!! Certainly seems like hell of a good time!
  15. #643
    Mar 2006
    SLC area
    Thanks!!
    Yea... the rotors have some grooves. I think they'll be ok for DD... I'll have to replace them before the next track event though. Once I heard them go.... I didn't touch the brake pedal again... so the damage is minimal.
    Still... totally worthwhile though. Best fun you can have..... better than sex
    Cruisin in the Brat till I get some new pads!! LOL
  16. #644
    Would Never, Ever Say Something Bad About an Admin's Mom SonicWagon's Avatar
    Jul 2007
    Santa Cruz New Mexico
    Congrats on the result!
    My parents had a 73 911rs when I was a kid and the brakes went out around 100milles from home. My mom drove the whole way home without the brakes. I was very impressed.
    "It is at our most challenging times that we must cheat our very hardest" - Eric Theodore Cartman
    Quote Originally Posted by Weasel 555 View Post
    so whose up for been banned?
    I is teh b1ggest douche evarrrr!~
  17. #645
    Mar 2006
    SLC area
    Lots of pics have been posted on other forums.... very few of me though
    Figure I'll start a pic thread of what I was up against - LOL
    I'll just add pics as I find them.
    The #1 Driver:
    The #2 Driver:
    The #4 Driver:
    The $5 Driver:
    The #6 Driver:
    The #8 Driver
    The #9 Driver:
