Ninfourteener's Progress Thread + Pics - Page 32
Page 32 of 59 FirstFirst ... 222324252627282930313233343536373839404142 ... LastLast
Results 466 to 480 of 885
This is a discussion on Ninfourteener's Progress Thread + Pics within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Check out the link in my signature "WRX track racing" Same track.... although different starting points.... and obviously different weather....
  1. #466
    "Supreme Subaphile Extraordinairre" ninefourteener's Avatar
    Mar 2006
    SLC area
    2006 Subaru WRX-Thread: http://www.clubwrx.net/forums/engine-modifications/165158-ninfourteeners-progress-thread-pics.html
    1978 Subaru BRAT-Thread: http://www.clubwrx.net/forums/engine...ss-thread.html
    2007 Subaru B9Tribeca Ltd (PSM)........1994 Subaru SVX LSi(SOLD)
    WRX 12 sec drag (vs. late model Camaro SS):http://www.youtube.com/watch?v=lw0vWdD2cjU
    WRX track racing (catching a stg.2 WRX): http://www.youtube.com/watch?v=mELeSD1Mi08
    Co-Founder/retired Admin-www.slcsubaru.com
  3. #467
    Mar 2006
    SLC area
    And they're off.......
    The WRX is officially "broken" for the next couple weeks.
    Rotora Front BBK
    STI brembo rears w/ DBA 2657 4000 series
    .. all powdercoated azure blue
    ...... coming soon
    2006 Subaru WRX-Thread: http://www.clubwrx.net/forums/showthread.php?t=165158
  4. #468
    Palmyra, NJ
    nice!
    Here's a question...can the WRX 4/2 Pot calipers fit on a Legacy GT/Spec.B?
  6. #469
    Mar 2006
    SLC area
    I "think" so.... I've seen it done with Brembos before.
    I can tell you all the info about brake interchangability you want to know on an 02-07 WRX... but I don't know much about Legacies, particularly the Spec-B, and any differences it may have from the "normal" Legacy.
    With that, check out the Nasioc Brake FAQ... lots of good info.
    I would look at the compatibility, based upon what size rotors you have. This thread lists all the different sizes of rotors, and quite a lot of good info about interchangability of calipers.
    Compiled brake information - NASIOC
    Added: Come to think of it.... the Legacy uses a 5x114 lug pattern I believe (just like the STI)... so it might be a plug-and-play type of thing.... with the exception of the parking brake.
    You might want to check out TRIBECA brakes as well.... not sure what you can use.... but the brakes on my Tribeca are MONSTERS. They aren't as impressive "looking" but I bet those rotors are just as big (if not bigger) than STI rotors.
  7. #470
    Registered User Crb03's Avatar
    Jan 2008
    southern cali
    you looking to sell those 4/2pots?
    "M3 drivers have no friends..." - Jeremy Clarkson
    "If something sounds too good to be true, it's best to shoot it to make sure" - Fiona Glenanne
  8. #471
    Mar 2006
    SLC area
    ^^ You're actually the 2nd person that asked me that - LOL
    Sorry, no.
    All 4 are getting traded for a front Rotora BBK + cash. They are all packed in a suitcase right now (100 lbs)..... The AF is sending me to a training conference in San Diego Friday morning. Making the trade while I'm there... I'll be coming back with the Rotora BBK
    I'm immediately buying rear STI brembos, and some DBA 2657 4000 series rotors with the $$ I'm getting from the trade, plus quite a bit out of pocket.
    All 4 new calipers are being rebuilt.... and powdercoated Azure Blue
  9. #472
    Palmyra, NJ
    Good brake thread. Thanks!
    In poking around on the LGT forums, I'm almost positive that all LGTs are actually 5x100 lug patterns.
    The Spec.b is actually no different from an LGT in regards to engine, braking, and most of the suspension. 07-09 Spec.B's have a 6-speed manual. All other LGTs have a 5-speed (if not Auto of course) that is what is used in the 09+ WRXs I believe. The 6-speed, contrary to popular belief, is quite different than the STI. Though it is very strong, its ratios are much different and the overall "feel" is supposedly not as tight or as confidence inspiring. Keep in mind this is all just the research I have done...I haven't actually test driven either a Spec.B or an LGT yet...but will this weekend.
    But the bread and butter, and the sole reason for the Spec.B designation are the Bilstein struts used in the suspension which improve handling dramatically compared to the LGT.
    I'm pretty set on an LGT or Spec.B becoming my next Subaru, pending some successful test drives of course
  10. #473
    Mar 2006
    SLC area
    They're here
    I found out, that the seals have actually recently been replaced.... it seems an awful waste to have to rebuild them again to powdercoat.
    So..... I've decided not to go the powdercoating route. It's cost me another $300+ to rebuild them all, so I'm going with the VHT + baking route.
    Worst case scenario, I can always powdercoat them in the future.
    They are already torn down as far as I can get them without replacing the seals/pistons..... already started the sanding/prepping/primering process... more pics up soon.
    DBA rotors and STI brembo rear calipers will be here on the 8th of Feb
    Pads for these monsters will be here around the same time.
    Rotora 4-piston calipers (10.5").... (up from 8.5" red 4-pots)
    Rotora drilled/slotted 13" rotors..... (up from 11.5" stockers)
  11. #474
    Mar 2006
    SLC area
    Spent literally all night doing the prepwork. Brake cleaner, and lots of acetone. scrubbing, sanding, and re-cleaning fron those irritating brake fluid drips.
    I got em all though.... scuffed them up nicely, and primed.
  12. #475
    Mar 2006
    SLC area
    Got em painted this morning... look awesome
    Getting ready to be baked at 200degrees for 1 hour.
    Then I'll apply the decals, the high temp clearcoat, and steel wool them a bit to smooth them out.
  13. #476
    Mar 2006
    SLC area
    I thought those looked a bit dark compared to what they "actually" look like.... so I took this picture with a flash:
  14. #477
    Mar 2006
    SLC area
    Baked and decal-ed
    clearcoating this afternoon/evening
  15. #478
    Mar 2006
    SLC area
    While the calipers were cooking and cooling..... decided to do a little "refresh" on my supertones.... and match the colors.
    Silver wheel paint was used on the center portion.
    exterior grills used the same VHT high temp, and baked them for an hour at 200 degrees.
  16. #479
    Mar 2006
    SLC area
    2 coats of clear so far. Still have to steel wool
  17. #480
    Mar 2006
    SLC area
    Supertones.... done
