Ninfourteener's Progress Thread + Pics - Page 10
Page 10 of 59 FirstFirst 1234567891011121314151617181920 ... LastLast
Results 136 to 150 of 885
This is a discussion on Ninfourteener's Progress Thread + Pics within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; hey bud quick question i dont know if you mentioned it in your theard or not but did you up ...
  1. #136
    Registered User Emsbuff124's Avatar
    Mar 2008
    Rockland County N.Y.
    hey bud quick question i dont know if you mentioned it in your theard or not but did you up grade your sturts at all on your car, i just brought a set of pink springs and im on the fence weather to up grade my struts or not, Also you may have mentioned it but what sway bars did you use on your car, im looking at buying a set of perrin 25mm front and rear sway bars kartboy endlinks and stout mounts from perrin, and last did you do an Anti lift kit or subframe lock down kit on your car
    i live my life a 1/4 mile at a time
  3. #137
    "Supreme Subaphile Extraordinairre" ninefourteener's Avatar
    Mar 2006
    SLC area
    Nope, struts are 100% stock, have 35K miles on the car, and still drives and handles great.
    I wouldn't recommend pinks though. Although they are a great spring, (Anything made by Eibach is - Cobb, SPT, Pinks, etc) they are going to re-create the same uneven stance as stock, just lower.
    For a moderate, high quality spring, I'd go with the Eibach pro-kit, or the prodrive springs.
    Swaybars.... none yet..... been spending all my time/money on the Brat. When i do though, i'm going with the Cobb 25mm setup.
    2006 Subaru WRX-Thread: http://www.clubwrx.net/forums/engine-modifications/165158-ninfourteeners-progress-thread-pics.html
    1978 Subaru BRAT-Thread: http://www.clubwrx.net/forums/engine...ss-thread.html
    2007 Subaru B9Tribeca Ltd (PSM)........1994 Subaru SVX LSi(SOLD)
    WRX 12 sec drag (vs. late model Camaro SS):http://www.youtube.com/watch?v=lw0vWdD2cjU
    WRX track racing (catching a stg.2 WRX): http://www.youtube.com/watch?v=mELeSD1Mi08
    Co-Founder/retired Admin-www.slcsubaru.com
  4. #138
    Registered User Pavia's Avatar
    Dec 2006
    Philly/DE area
    Just finished reading all ten pages. Sweet looking ride and I appreciate how you stuck to a theme in your mods.
    I found it looking into the STI Brembos on the stock WRX rims. I also have winters on the stock 17x7s. Good to know they don't fit over the Brembo calipers.
    ...but then it might be a good excuse for some 04 STI gold rims for the winter
    P.S. I would consider replacing your stock Throttle Body to TMIC coupler with a silicone coupler w/ t-clamps (in blue, of course, to match your other hose. Mine kept slipping a little bit with the increased boost on the STI turbo, no matter how much I tightened the stock clamps. I noticed yours had the same slip (look at the slight gap between the coupler and the protruding mark on the TB. You never know if the hose might slip off enough to affect boost one day...
    06 GTO M6 Quicksilver, SLP 455 Bobcat, LS7 Clutch w/ SS line (RPM tune:373rwhp/373rwtq)
    07 WRX TR M5 Garnet Red Pearl w/ Straight PPGs and Cusco front LSD (Agile tune:307whp/343wtq)
  6. #139
    Mar 2006
    SLC area
    You know, I never noticed any slippage between the throttle body and the coupler..... I have to admit though, I haven't "really" looked either.... I'll have to take a look tonight.
    Keep in mind, I have that coupler drilled and high-temp rtv'd to have a temp sensor in there (post intercooler intake temp).... means I have to do that process again.
    Thanks though.... I'm gonna take a look tonight.
    2006 Subaru WRX-Thread: http://www.clubwrx.net/forums/showthread.php?t=165158
  7. #140
    Mar 2008
    how do you like the short throw shifter i just pick up a kartboy short throw for 50 bucks, and i just brought the front and rear bushings for it along with a kartboy knob
    what the stock knob hard to take off the stock boot???
  8. #141
    Dec 2006
    Philly/DE area
    Quote Originally Posted by Emsbuff124 View Post
    I have the Cobb and it's not bad, but I think the Kartboy is better.
    Stock knob is easy, just unscrew and pull it off the boot. Then go to Redline goods and get a nice italian leather boot.
  9. #142
    Mar 2006
    SLC area
    Well, my battery left me stranded 2 days in a row out in the cold....... figured it was time for an upgrade.
    I'm "Optimized"
    I've heard nothing bit good things about Optima batteries..... supposedly they are the best that money can buy. God I hope I didn't just waste a buttload of cash on a battery,
  10. #143
    Registered User Dhbamby's Avatar
    Jan 2008
    Lanc Lanc PA
    i herd that black shell batterys are the best and white ones are weak... i heard that a store wont even take the white ones back as a core exchange?
    MY Mods...
    2004 WRX OPB....58k...open source tuned...VF 39 Turbo...Pink 565cc injectors...Walbro FP... Godspeed FMIC...Turbo XS Stealthback Exhaust...Gimmik Turbo Inlet...Gimmik Rad. Hoses...COBB SF Intake...EXedy Lightweight Flywheel...F1 Racing Stage 2 Clutch...Perrin Crank Pulley...Perrin Afta-MAF Hose...HKS Up Pipe...Kartboy Short Shifter and Bushings....lots-o-suspention...
  11. #144
    Mar 2008
    Quote Originally Posted by ninefourteener View Post
    I'm "Optimized"
    i thought the yellow batteries were the best to get maybe i could be wrong, also did you look at upgrading your alternator maybe that could be the problem especial if you have aftermarket speakers radio gauges etc etc
  12. #145
    Mar 2006
    SLC area
    Yea, I think the yellow top batteries are considered an upgrade, but I had a hard enough time spending $159 on a battery... the yellow top version was $210.
    I don't think there is a "problem" with my charging system... I intentionally never installed amps and subs to save weight... and my gauges are all low-wattage LEDs. My OEM battery was 3 years old, so it was about time for it to go anyway.
  13. #146
    Mar 2008
    oh i know everything is way out wack now a days honestly i mean come on 210 for a battery 70 years a good you could get a well used car for that price if you knew were to look lol
  14. #147
    Jan 2008
    Lanc Lanc PA
    yeAH but who would want a used car from 1939 as a DD???
    MY Mods...
  15. #148
    Mar 2008
    Quote Originally Posted by Dhbamby View Post
    lol but the 1939 today if it still runs and restored is worth as much as an new STI lol
  16. #149
    Mar 2006
    SLC area
    So..... as if my battery going out wasn't bad enough........ my car left me stranded after sitting outside for 4 days. I cranked the hell out of it, and the new optima didn't even show signs of slowing down..... and it was 6 degrees outside.
    My fuel pump "froze"...... no BS...... turned over for 20 minutes.... literally.... got zero fuel pressure.
    After pushing it through the snow (ugg) into the warm garage.... with a space heater blowing under the backside.... the pump finally kicked in again. Nevertheless, I assumed it was on it's way out the door.......... so I headed down to Rallysport direct and picked up a Walbro..... what the hell? IO figure if I'm gonna do it... I'll do it right, you know?
    Got the Walbro in and working..... doesn't seem much different than the stocker..... but at least I know it's "new"..... and I shouldn't have the same "cold" problems as before.
    Not too bad of an install...... about 2 hours..... little tricky getting the pump on the whole assembly.... kinda had to take everything apart and then put it back together..... the pump wouldn't just simply "slide in".
    Anyway..... here's the monster:
    The old pump + assembly:
    The new pump... installed:
  17. #150
    Jan 2008
    Lanc Lanc PA
    nice... you had the install kit right? i just installed the pump, it was a PITA
    MY Mods...
