What is the easiest least expensive turbo swap?
Results 1 to 15 of 19
This is a discussion on What is the easiest least expensive turbo swap? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I have an 06 wrx tr and i wanna upgrade the turbo but i dont wanna go nuts its a ...
    Nov 2006
    Question What is the easiest least expensive turbo swap?
    I have an 06 wrx tr and i wanna upgrade the turbo but i dont wanna go nuts its a daily driver i was wondering what would be the most reliable least expensive swap thanks
    May 2005
    Phillytown, PA
    Probably a VF39 swap. You can find a used STi VF39 turbo for usually ~$400 and if you have a Cobb AP you can use an OTS map.
    Nov 2005
    The Holy Commonwealth of Pennsylvania
    +1 on VF-39. It's a bolt on.
    All you really need is Cobb AP (or some other EM, Cobb has OTS maps for free tho), STi TMIC (get em used for around 200-300) w/ the splitter and bellows, and a nice low mileage VF-39.
    Your injectors are good and fuel pump won't need to be upgraded (but it wouldn't hurt).
    May 2005
    Phillytown, PA
    I'm not sure I would bother with a VF39 on a 2.5L motor though, but anywho.
    GraysonSubaru's Avatar
    May 2005
    Knoxville, TN
    VF39 would be the least expensive, but i would just hold off until i could get an 18g..
    18g is the smallest i would bother with on the new 2.5L
    Hey, being the forum car ADD guy is better than being the forum OG.
    Well nobody cares what you think, Seth
    Registered User LeeC's Avatar
    Oct 2005
    Baltimore MD
    Check out proven power bragging on nasioc, a few guys are making real nice numbers off of vf39's on their 2.5 wrx's.
    94 Anthracite 6spd Supra - 9.87@147
    LS2 RX7-2014 Tundra DC-GD Race Car In Progress
    Feb 2005
    oregon
    vf39 is a peice of crap, you'd have to have ported due to spiking issues, why upgrade to a worked over peice of crap? but. . . yeah it may be the easiest due to fuel system and mail order tuning. maybe you can run a 16g on stock fueling with a custom tune, but thats just an idea. i'm no expert. i agree with the addage 18g or bigger on 2.5.
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Cobb has an OTS 18g map as well.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    May 2005
    Knoxville, TN
    Quote Originally Posted by 06wrx4me View Post
    that i did not know. it is for the 2.0L??
    Jun 2006
    Nor Cal
    Quote Originally Posted by GraysonSubaru View Post
    Looks like its only for the 2.5l. The FP18g map came preloaded on the V2 AP with your 3 fuel choices. So if he has a 2006 the AP has an OTS FP 18g map.
    Just looked on Cobbs website for 2.0l looks like no dice, but they do have an FP16g map.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    Registered User bcyb1029's Avatar
    Feb 2006
    Chicago
    VF39 to small, 18g is the way to go.
    Tuned by Jorge at P&L, 240.83whp 239.60wtq at 14.8psi on 2.0L with stock td04 (But doesn't run)
    Mar 2003
    lincoln, ri
    lots of people don't seem to read too well.
    the easiest, least expensive is the vf39, no question, 100% without a doubt. there is no discussion. you can get a 39 for <200 bucks, and EASILY get into the 12s with decent driving.
    this is an sti list, but remember--you've got one less shift:
    http://forums.nasioc.com/forums/showthread.php?t=959316
    May 2005
    Knoxville, TN
    I can read...my original post:
    Added: the VF39 can create some problem due to spiking and cracking. Several people on the forum have done the VF39 upgrade and had problems. Of course there are others that have not had any problems. thing is there, if it cracks, you are out of luck and the $$ that it cost you.
    with the 2.5L, i would suggest the 18g, plus it has a warranty so if it does fail in their guidelines, they would replace it.
    Mar 2003
    lincoln, ri
    how exactly does the crack affect performance?
    i personally know multiple people with cracked p17/p18 housings and it doesn't make an iota of difference in performance. the crack goes between wastegate port and the main turbine outlet, and is almost never more than a fracture (ie, no space between broken parts).
    on the other hand, the crack did make a difference in that it ended up saving them 100 bucks on the price of the turbo.
    May 2005
    Knoxville, TN
    Quote Originally Posted by ride5000 View Post
    if you are going to have it port and polished, it does have an effect. plus the 39's are notorious for boost creep unless you go through the trouble of a bigger waste gate...which just adds to the cost of the turbo setup as a whole.
