| Home | Forums | Photo Gallery | Groups | Shirts and Stickers | Advertise |
| Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Engine Modifications Flat-fours and turbochargers are what set the WRX apart from the rest. Talk about them and the latest aftermarket parts here. |
| Advertise On ClubWRX | |
LinkBack | Thread Tools | Rate Thread | Display Modes |
#1 (permalink) |
AVO Boost Control Actuator
Hey guys... I was looking around on www.rallitek.com and found this Boost control actuator. I searched for Boost Control Actuator info. Just kind of wondering if it is worth the 180 or what. I read the article and it sounds like it is makes more solid boost and for 180 plus labor did a pretty good power increase on the sti! So tell me
looks to be just a better wastegate? let me know guys thanks |
#2 (permalink) |
Not worth it.The factory one is adjustable to a point and if you surpass that you can jus use a $2 helper spring.
__________________
Aarrg matey!!Ecu pirated by RomRaider! My Mods My Picshttp://www.cobbtuning.com/info/?ID=3223 http://web.archive.org/web/200510160...machvcorner/29 http://forums.nasioc.com/forums/showthread.php?t=533787 |
#3 (permalink) | |
Quote:
If anybody is using this AVO Solid Boost Actuator, please reply if you felt any difference or not. |
#4 (permalink) |
It shows an increase because it is over riding the factory boost mapping,just as an MBC does.It clearly says in the dyno graph that it increased the boost .25 bar(3.5psi) over stock.Gotta look at the details.Any tune will remap these areas.
__________________
Aarrg matey!!Ecu pirated by RomRaider! My Mods My Picshttp://www.cobbtuning.com/info/?ID=3223 http://web.archive.org/web/200510160...machvcorner/29 http://forums.nasioc.com/forums/showthread.php?t=533787 Last edited by Donkey; 03-22-2009 at 05:47 AM.. |
| Bookmarks |
| Thread Tools | |
| Display Modes | Rate This Thread |
