Nitrous Express N-Tercooler System - Page 2
Results 16 to 30 of 34
This is a discussion on Nitrous Express N-Tercooler System within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by bkotzman00 I got the solenoid on ebay, it is a little overkill (able to handle 250psi at ...
    Registered User Aerophyre's Avatar
    Jul 2003
    Tempe, AZ
    Quote Originally Posted by bkotzman00 View Post
    I got the solenoid on ebay, it is a little overkill (able to handle 250psi at the inlet) but as for set up not 100% sure will probably just wire it into my home made water sprayer so they both spray at the same time so that the CO2 super cools the water, which should be more effective then just spraying it dry
    When you get it done post a how to. Im very interested.
    Registered User bkotzman00's Avatar
    Apr 2006
    York, PA
    Quote Originally Posted by Aerophyre View Post
    I'll try it will be awhile in the making plus there will be some metal working that might be over some people's head like how I made the spray ring from aluminum piping
    04 WRX Java Black
    Mustang Dyno 218 awhp 216 awtq
    1978 Honda CB400Tll
    yea you know its modified
    1974 Honda CB750 Bobber
    still in the works
    Registered User version8's Avatar
    Dec 2006
    Under the bonnet
    Gagging to hear your results. It's exactly what I'm looking to do. Buying the kit seems pricey when you look at the parts needed to make it.
  6. #19
    Apr 2006
    York, PA
    Quote Originally Posted by version8 View Post
    alright since people keep asking, I have not finished it yet (no rush since it is winter and already 40 outside) but I will show the parts I have with ap. cost. the only parts I still need are a momentary switch that handles over 1 amp and a high pressure hose to run from the trunk to the engine but here you go:
    the spray ring sitting on the intercooler (I think I will use cable ties to attach it)
    the ring itself made from 1/2 inche OD by 1/4 ID aluminum tubing that I got for free but would cost at hardware store about $7 for 3 feet
    a close up of the spray ring, these holes are angled downwards (not straight down so the middle of the IC can get some) and are all around the ring
    these are the other parts: 3lb. CO2 bottle (ebay $30) attached with a paintball CO2 remote (ebay $15) and the overkill 250 psi selonoid valve (ebay $50) the bottle will be mounted in the trunk with a high pressure line running off the remote to the engine where I will fab a mounting bracket for the selonoid valve that will bolt to the IC mounting points and then that will attach to the spray ring
    I will try and make the CO2 system and my homemade watersprayer work together so 1 button to 2 spray setups. sorry for the hijack from the original topic
    04 WRX Java Black
    1978 Honda CB400Tll
    still in the works
  7. #20
    Banned C89ZX7R's Avatar
    Jun 2006
    Richmond Virginia
    the pic of the bar above this post is not going to cool like a normal one would , thats connected to both side of the connector . the co2 on his will have to make a journey all the way around the bar since its only feeding one side of it . think about it . you take his bar and use it on the intercooler say its 300 degrees so the end of his bar is going to be extremely hot and the temp drop on the end will be way less the using one that is fully connected . if its was fully connected the rear section would be cooler then the front section since it would be going around from both sides . his has to go all the way around the bar , meaning the co2 is heating up and when it gets to the end where its even hotter he won't get the drop of temps he is looking for .
    why does it seem like this must be a new thing , lol bunch of noobs .
    we did this on a friends turbo escort and it made one hell of a improvement , before he could hang with me when i was running 40 psi on a 16g with two 1150cc injectors back it up on the conquest tsi , after we did it on his car he was right beside me when he sprayed the intercooler .
    for the ones who said you would have to have the valve near you , your so wrong . guess you never seen this ( the remote bottle opener )
    http://www.jegs.com/webapp/wcs/store...26143_-1_12033
    http://www.jegs.com/webapp/wcs/store...18795_-1_12033
    and here is the kit i'll be using , 10lb kit , fuel bar chiller , intercooler piping chiller bulb , and intercooler chiller .
    http://www.designengineering.com/pro...asp?m=sc&cid=1
  8. #21
    Jun 2006
    Richmond Virginia
    whats the max psi for the bottle before it explods
  9. #22
    Dec 2006
    Under the bonnet
    Quote Originally Posted by C89ZX7R View Post
    That's the components that I was considering using. Kinda hard to get way out here though.
  10. #23
    Jun 2006
    Richmond Virginia
    way out where ?
  11. #24
    Registered User Very-Rexy's Avatar
    May 2006
    Warner Robins AFB 30,000 feet
    way out where ?
    I'm guessing England. "Under the Bonnet"
    06 WRX - Deadbolt Zilla 20g 365AWHP//358AWTQ//TopSpeed
    STi Drivetrain installed by CRE
    Hawk-Eye Alliance #54
    My mod list
  12. #25
    Apr 2006
    York, PA
    what you say is true and I wanted to do that but, my welding skills for steel with a mig are great but my skills with a tig and aluminum are nilch so I had to do it that way since I could not weld the loop together. I was thinking that by using smaller vent holes that then the air volume in will be higher then the air volume out so the pressure across the bar would be almost equal if that makes sense. But this is my first time making anything like this and just plugging away at it learning new stuff all the time, I just enjoy tinkering and was just showing what I have but thanks for the critique it gives me ideas that I may not have thought of myself
    as for the max psi of the bottle, it is the same valve top as a paintball tank and I had it filled at ****'s so the pressure I would think would be about the same as with a normal paintball tank but I don't know the max psi
    04 WRX Java Black
    1978 Honda CB400Tll
    still in the works
  13. #26
    Jun 2006
    Richmond Virginia
    make sure the bottle doesn't explode from raising pressure from the gas inside on hot days . it will get hotter in a car then under someones arm
    need to find out the mas psi for the bottle if its lower then the valve you may have some serious problems
  14. #27
    Dec 2006
    Under the bonnet
    Quote Originally Posted by Very-Rexy View Post
    Oh yeah. Didn't realise how much of a give away that would be. Should've said under the hood
    New Zealand. If anyone wants to ship parts my way it would make things so much easier
  15. #28
    Jun 2006
    Richmond Virginia
  16. #29
    Apr 2006
    York, PA
    true the warning lable on the bottle says not to have in an environment higher than 130 F and the trunk doesn't seem to get as hot as the cabin does in the summer but I am going to contact the manufacture to make sure thanks
    04 WRX Java Black
    1978 Honda CB400Tll
    still in the works
  17. #30
    Nov 2005
    Central Florida
    bump for updates
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
