How to: Air Box Silencer Delete - Page 7
Page 7 of 8 FirstFirst 12345678 LastLast
Results 91 to 105 of 110
This is a discussion on How to: Air Box Silencer Delete within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Neems any suggestions if i take my wagon to the desert? my only worry is that sand ...
  1. #91
    Quote Originally Posted by Neems
    any suggestions if i take my wagon to the desert? my only worry is that sand might get into the motor...
    You're not removing the factory airbox (which has a filter), just the snorkus from the fender
    Resident Tuner @ WTF Tuning
  3. #92
    Moderator Donkey's Avatar
    Da boonies,Va
    +1 uuumm.........yeah if you planned on removing the whole airbox maybe this mod isn't for you. Regardless even if you leave the snorkus on what makes you think sand won't end up at the same place as it would with out it?
    2002 FORESTER S
    1998 FORESTER S
  4. #93
    Jun 2010
    Bringing this thread back form the dead!
    Does this apply to the 2010 WRX model? Is there an air silencer to remove? Guess I need to get more familiar with my car.
  6. #94
    Jul 2010
    Yes, I just did this on my 2010. Takes 2 minutes - loosen the two plastic screws holding the snorkel in place at the front of the engine and it comes right out.
    Quote Originally Posted by SirVilhelm View Post
  7. #95
    Da boonies,Va
    Quote Originally Posted by finally fast View Post
    You removed the front air scoop,which I suggest putting back in.
    2002 FORESTER S
    1998 FORESTER S
  8. #96
    Registered User cjm1991's Avatar
    Jun 2009
    st louis
    +1. The part your trying to delete is in your front passenger side fender. Youll need to remove pins in the wheel well to get to it. Also theres a couple bolts holding it on, super easy though. Did mine when I put my intake on, took 15 mins max including the SR install.
    Chris
    02 Camaro z28 T-Tops, m6 49k miles
    Bolt ons and tuned - 349rwhp/362rwtq
    02 Ws6 T-Top,m6 80k miles
    Bolt ons/Cam/tune - 436rwhp/424rwtq
  9. #97
    Da boonies,Va
    Quote Originally Posted by cjm1991 View Post
    The 08+ don't have an intake resonator/silencer.....
    2002 FORESTER S
    1998 FORESTER S
  10. #98
    Jun 2009
    st louis
    I didnt notice it was a newer one.
    Chris
  11. #99
    Registered User SKI.WRX's Avatar
    Jun 2010
    Colorado
    Just did this mod to my 02 and I LOVE the sound. It also feels like the turbo spools a little faster even if not by much. Thanks for such a thorough write-up, only took 20 minutes or so.
  12. #100
    Registered User d_Ziggy_2000's Avatar
    Jun 2010
    Seattle(ish)
    I also just did it in about 20 minutes. I only in did the very front of my underbody protector thing and dropped it right on out. I dunno if its justme but my turbo seems to spool sooner and seems to be slightly faster =)
    '88 Sub Justy *Rock in oil pan killed on freeway
    '87 Honda Civic *Bad pistons (to lazy to fix)
    '85 Nissan 200sx *Blown engine drifting
    '00 Sub Outback *Mother literally stole
    '92 Toyota Tercel *Hated it
    '02 WRX '07 kawasaki ninja. * current
  13. #101
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    Apologies for bringing this back, but you don't need to remove the front wheel or even jack up the car to get the silencer out.
    Quote Originally Posted by d_Ziggy_2000 View Post
    +1 on this.
    I just cranked the wheel to the right until full lock, then unclipped the the outer clips around the wheel well, plus the two underneath. For the silencer bolt located inside the wheel well, just remove the fog light (three Philips screws on the outside, plus the power plug in back), and the bolt is easily accessible right behind the fog light hole.
    I just wiggled the silencer around until it came out. The underbody protector flexes quite a bit, so don't worry too much about tearing it, just watch what you're doing, and you should be fine.
    I was doing this on a slight incline in the rain, so I wasn't interested in jacking up the car for any reason. This way only took me 20 minutes or so and was easy peasy
    2007 Outback 3.0R wagon
  14. #102
    Sep 2010
    This maybe a silly question...
    I'm going to attempt to do this today.
    The question is, I don't know where to get the elbow and I kind of just want to do it without looking or waiting for one.
    So is there a possible way I could cut off the bottom of the silencer and tape it I think I've heard of this but I'm not sure...
    Any advice?
  15. #103
    Registered User lytlec's Avatar
    Jan 2009
    Central PA
    Quote Originally Posted by s.subi View Post
    Any advice?
    http://www.fastwrx.com/insnre.html
    DIY: Intake Silencer Elbow
    <-------- Taylor Swift.
    Hawk-Eye Alliance #137
    First Mods...what to do.
    Subaru Guide
  16. #104
    Sep 2010
    Oh so it be best just to use the elbow?
    If I just completely take it out will it be bad?
  17. #105
    Jan 2009
    Central PA
    Just do what the guy did in second link!
    Subaru Guide
