2002 WRX Boost Spike? Help - Page 2
Closed Thread
Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
This is a discussion on 2002 WRX Boost Spike? Help within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by momo02WRX Thanks for everyone's insight. I called Subaru this morning and they quoted me about 30.00 for ...
    Oct 2004
    Westchester Cnty, NY
    Quote Originally Posted by momo02WRX View Post
    I called Subaru this morning and they quoted me about $1430.00 for the parts and labor (including flywheel) for a new clutch. F*** that. I'm thinking about buying the parts and having a mechanic thats a friend of the family do the work, because I still don't feel comfortable doing it myself with a sloped driveway and limited tools. I was looking at either ACT, Exedy, or XTD. Has anyone had experience with these brands? Some other brands I saw on Ebay for cheaper include EZ Racing, F1, and Boss clutches.
    Thanks
    You should price out a OEM brand new clutch. It's not like your power is too much for it. It's just that yours was old and warn.
    Oh and I would go see a certified tech, preferably one that knows subies to check out your car and diagnose it before you order clutch parts in case we are all wrong.
    2015 Plasma Green Pearl XV Crosstrek Hybrid Touring
    2011 Lightning Red WRX LTD Sedan w/ Nav (returned)
    2008 Lightning Red WRX Prem. Hatch w/ Nav (returned)
    2005 San Remo Red WRX Prem. Sedan w/ VF34 (traded)
    Quick reply to this message Reply
    Registered User BlkWRXWag's Avatar
    Jan 2003
    Trabuco Canyon, CA
    Stick with the OEM clutch and flywheel - your gearbox will thank you. The price quoted by the Subaru dealer is their normal price and includes a new flywheel (which I would recommend). You may find an independent shop to do it a bit cheaper, but make sure they know what they are doing. I've had one done at thee dealer and I've done one with a friend. The money is almost worth it to have the dealer do it!!
    -Max.
    06 STU STI
    2006 STU Pro Solo Natl. Champ.
    www.zzyzxmotorsports.com
    Registered User momo02WRX's Avatar
    Sep 2006
    SRQ, FL
    Quote Originally Posted by D0WNxSH1FT View Post
    The extra power of Stage 2 (55whp over stock) could have put your 4 year old clutch over the edge.
    Def data-log. Sorry more people arent on right now to help.
    I finally downloaded the ecuExplorer software and did some datalogging. I thought their would be something called boost pressure, but no, so I am assuming that manifold relative pressure(MRP) is the the boost. (someone please correct me if I am wrong). Going through the city, I managed WOT in 3rd gear and MRP/boost peaked around 13.8. I then took it to the highway and got WOT in 4th and 5th gear and it peaked at around 15.7 psi... later with the pedal floored doing about 100 mph it peaked at 15.961 psi. So it appears that I have no bad boost spike. So, as many of you have mentioned, its probably my clutch slipping, not boost spike. I will probably take it to Subaru in for a final decision.
    Here are some other #'s from my datalogging. I don't know what they mean but maybe they are entertaining to some of you:
    Manifold Absolute Pressure - peaked 30.616 psi
    Mass air Flow - peaked 156.28 g/s (minimum-1.73, idle - 4.75ish g/s)
    Ignition timing - minimum = -10, idle = 12-13, max = 43
    Primary Wastegate Duty Cycle = max 97.65 %
    02 MBP Stg 2 Bugeye
    Bugeye Mafia #107
    WRB '02 Stage 2+ WRX - SOLD (and dearly missed)
    07 OBP WRX (Wife's) SOLD
  6. #19
    Sep 2006
    SRQ, FL
    Quote Originally Posted by BlkWRXWag View Post
    Thanks, I called a different dealership in Tampa, and they quoted me about $200 less for the new clutch, flywheel, and labor, so maybe a couple more calls and I'll do it.
    02 MBP Stg 2 Bugeye
    Bugeye Mafia #107
  7. #20
    Sep 2006
    SRQ, FL
    I think I have a better way to describe my clutch/boost spike dilemna. Its that feeling like you step on the gas in an automatic on the freeway and the rpms's jump up, then it shifts and they go back down. I have checked out my boost gauge/AP handheld, and datalogging and still have seen no signs of boost spike so it has to be my clutch. Thanks for everyone's help.
    02 MBP Stg 2 Bugeye
    Bugeye Mafia #107
  8. #21
    Sep 2005
    Tallahassee, FL
    I haven't tried it on the highway yet, but I just picked up a bone stock 02 wrx wagon and notice quite a bit of chatter, to the point when the car doesn't go sometimes b/c the chatter is so bad. I don't want to have to spend another $1100 when I JUST bought the car... If it is infact the clutch, why would I only want the stock oem one? I plan on doing the stage 2 mods down the line.
  9. #22
    Jun 2006
    i'm wonering if i am having a simlar problem, my car does this, but it IS during shifting. i have a helix catless TBE, and even if i fully let off the gas between shifts it still goes vroom, up about an extra 500-1000 rpm. but more-so when i am driving hard. but its been doing it ever since i've had the car, for about 2 months. or is this normal.
    my boost also gets up to where it normally does, but then it will bounce down a few psi and back up. hopefully it will stop when i get an AP, and not cause any damage in the mean time.
    sorry to piggy-back your thread btw
  10. #23
    Sep 2005
    Tallahassee, FL
    Quote Originally Posted by jester458 View Post
    Mine does this too when I shift and driving spirited. The rpm's go way up. All people have told me is that it's the way I shift. Even if I'm all the way off the gas before I clutch it still does it. Makes no sense to me at all. Mine's an 02 with 72k miles, stock everything, original clutch.
  11. #24
    Sep 2006
    SRQ, FL
    I am pretty sure its normal. I have an '02 with 80K+ on it and it has always done it occasionally. I am pretty sure your clutch isn't slipping if this is the only symptom.
    02 MBP Stg 2 Bugeye
    Bugeye Mafia #107
  12. #25
    Jun 2006
    yeah i didnt really think it was the clutch slipping, but i just thought i'd ask. maybe it is just the way i shift.
  13. #26
    Registered User WyomingWagon's Avatar
    Dec 2013
    wyo
    If any knowledgable scooby specialissts would like to take e quick peek at this data log from a wide open throttle i am having a hard time diagnosing this boost spike. right at 4700 rpm i jump from 15 to 19.7 psi then right back down.
    no cel or fuel cut. this is a link to the log. thanks https://drive.google.com/file/d/0B0p...it?usp=sharing
    I have UP, TBE, turbo inlet, injectors, and intake + cobb V2
  14. #27
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by WyomingWagon View Post
    no need to bump TWO old threads..
  15. #28
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    PLEASE start your own thread... it will be YOUR thread and we can help you
    And ah.... closed!
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
Closed Thread
