coolingmist
Results 1 to 15 of 16
This is a discussion on coolingmist within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; anybody used their product? I am looking into their water/alcohol injection setup for my car and was curious if anybody ...
    Registered User Cavadini's Avatar
    Feb 2004
    Lincoln, NE
    coolingmist
    anybody used their product? I am looking into their water/alcohol injection setup for my car and was curious if anybody had any experience. Looks pretty good to me but just unsure.
    07 Mercedes-Benz E350
    Saks Fifth Ave Edition
    04 WRX VF34+TMIC SOLD
    12.62@108 1.7 60'
    295whp & 302tq on Mustang Dyno
    MODS
    Moderator timber's Avatar
    St. George, Ut.
    :subscribes for info:
    "Never Launched"
    Dougie
    - Founder, 250,000 mile club
    -5,000 posts
    Registered User bigd's Avatar
    Oct 2004
    Denver
    I was looking into these guys about 8 months ago.. They seem to make pretty good products, especially considering the price. The whole water/alkie/meth thing intrigues me and scares me. I think I may get tuned without it, then try it as an additional safety net. I don't want to tune FOR it, because if it goes then your fackedded.
    Dave
    01 RS
    Apr 2003
    Have you looked into the SMC kit?
    Feb 2004
    Lincoln, NE
    Quote Originally Posted by Chunks
    link or ban
    12.62@108 1.7 60'
    MODS
    Apr 2003
    Feb 2004
    Evansville, IN
    I run a Coolingmist single stage 150psi kit, excellent kit for the money I paid for it....been running it since November w/ excellent results..
    1988 Celica Alltrac
    Hallman Pro, 15x7.5 +20mm Rota Slipstreams
    2005 LGT 315whp/340wtq@21psi - Sold
    VF52, Crucial P&P&C Manifolds, UP, DP, RP, Magnaflow CBE, Hallman PRO, ROMRaider
    2003 WRX 371whp/355wtq@24psi - Sold
    TD05H-20G-38mm Tial, Meth Injection, Hyperflow TMIC, ROMRaider
    Dyno Chart METH vs 93 oct
    Feb 2004
    Lincoln, NE
    Quote Originally Posted by testes1010
    THERE WE GO. I thought somebody on here was running it that I liked the results of. I am thinking i really can't go wrong. It's almost 200 less than most other alky kits and a lot of people like it. Did you tune your utec to fire it off as a secondary solenoid or did you just use the boost pressure thing it comes with and tune accordingly on your UTEC for the higher load collumns when you're past that boost setting?
    12.62@108 1.7 60'
    MODS
    Feb 2004
    Evansville, IN
    Quote Originally Posted by Cavadini
    I just used the boost pressure trigger in the UTEC parameters...you'd need a super quick acting solenoid to control the spare Map solenoid...
    Jorge tuned my setup but it goes like this:
    - trigger alky at desired pressure
    - wait for slight increase in AFR
    - pull fuel increasingly thru the load columns
    - add timing & boost in same fashion...
    mine was dynoed initially to trigger at 12psi, after getting it out on the highway a few times it knocked during 3rd gear down shifts, fuel was being pulled before alky was being supplied. I lowered the trigger to 10psi, no issues now...
    1988 Celica Alltrac
    Registered User djerickd's Avatar
    Jun 2001
    Tampa, FL
    Go for it man, it's so simple to do and meth and water is cheap! Get a good tune with it tho. It's like race gas on demand, and cooling mist has one of the best pumps (besides aquamist). I just saw the stage one kit on ebay for like 215. This is next on my list of to-do's along with EWG...
    Feb 2004
    Lincoln, NE
    so you set the boost pressure trigger in the UTEC parameters AND you also set the adjustable boost pressure switch that the kit comes with to the set boost level? What all needs to be connected to the UTEC for it to know what to fire? And lastly, do you have any maps of alky when you were on the 30 that I could use as guidelines at all?
    12.62@108 1.7 60'
    MODS
    Mar 2002
    Calmer than you are
    aquamist isn't cheap, but its good.
    they even make a direct-port water injection kit.
    I modeled my IC sprayer on their kit.
    go f*** yourself
    Feb 2004
    Evansville, IN
    sorry, I never had alky with the VF30...Jorge added around 5.5 degrees of timing in the 100% column if that help & tuned it to approx. 12:1 AFR...
    just run the UTEC or just run the pressure switch...not both..
    here's the diagram I made up when I installed mine, the arming switch was another fog light switch I bought from a forum member....you need to be able to disconnect the alky w/ a regular pump gas map, an arming switch allow that...
    1988 Celica Alltrac
    Feb 2004
    Lincoln, NE
    thanks jeremy, you've been a HUGE help!!
    12.62@108 1.7 60'
    MODS
    Jun 2001
    Tampa, FL
