Heartbroken.....I blew my engine!
Results 1 to 9 of 9
This is a discussion on Heartbroken.....I blew my engine! within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Well, after 134,000 miles and 14 years, my 2002 WRX gave up the ghost. After a hard pull to redline, ...
    Registered User psychobooe's Avatar
    Mar 2004
    USAF
    Well, after 134,000 miles and 14 years, my 2002 WRX gave up the ghost. After a hard pull to redline, I spun a rod bearing. I love this car, and I want to drive it until it rusts away to nothing under my feet. My local mechanic quoted my $4500 to install a remanufactured engine with a 3 year warranty. I thought that was high, but after calling a couple places around the country, it may be a reasonable price.
    Enough of the sob story...what should I do at this point. As far as goals, I just want to get my car back. I have been Stage 2 since 20,000 miles, and I'm very happy with the power. I really just want my car fixed. My mechanic is not comfortable with rebuilding the engine, and I've been told that I'd be better off getting a remanufactured engine anyway. What is the best company for remanufactured Subaru engines? Is there another path that I'm not considering? What other mods should I accomplish while she's in pieces?
    As always, thanks for the help!
    Andy
    Try not, do or do not. There is no try. - Yoda
    Mods
    lit fam XJman's Avatar
    Feb 2015
    At work
    Brand new ej 205
    http://www.flatironstuning.com/p-208...hortblock.aspx
    Reman engines are not usually as reliable as new from the factory. That option is plug and play and as long as the heads are good you can just go about your day after the install. That's just my opinion.
    Sent from my Nexus 6 using Tapatalk
    For External Use Only irickchad's Avatar
    Sep 2013
    WV
    I second just getting a new factory shortblock, unless your mechanic just refuses to do any engine teardown.
    If that's the case, a local performance shop putting in a new EJ205 would probably be in the same realm price-wise as the remanned engine.
    I have an STi with an intake and no tune, I never change my oil, and my wheel spacerz are mad tyte.
  5. #4
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    +1 on the OEM replacement.
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  6. #5
    Feb 2015
    At work
    Honestly the fact Subaru still makes the 205 new is astounding
  7. #6
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by XJman View Post
    Do they still manufacture or are the remaining 205s from a safety stock to support the car through obsolescence?
    I'd expect the latter
    Facebook me here
  8. #7
    Mar 2004
    USAF
    Thanks for the help everybody!
    I'll be getting a brand new Subaru short block from Flatirons, and my heads will be reworked locally. I'll use all new gaskets and vacuum lines as well as a new oil pump and oil cooler. While the engine is out, I'll do a new turbo inlet and engine mounts too. I plan on reusing my timing belt and water pump as they were just changed as 100K. Does anyone see an issue with that? Any other advice will the engine is out?
    Thanks so much!
  9. #8
    Sorry to hear
    Quote Originally Posted by psychobooe
    Perrin inlet
    Consider Group-N mounts; they're only about $50-60 more than new OE, and if you're replacing them, you may as well upgrade.
    Replace them. You're looking at a few hundred when you're already in the thousands; peace of mind, IMO.
    New thermostat / thermostat gasket ($25-30)
    New aux belts ($25-30)
    New coolant hoses ($25-30)
    Steering rack bushings ($75)
    How was your clutch (if applicable)? With the motor out, it shouldn't be much labor cost (just parts) to replace that with a new Exedy OE replacement kit and a new flywheel.
    2005 WRX STi (Mods | Virtual Dyno) - Weekend Warrior
    Resident Tuner @ WTF Tuning
  10. #9
    Feb 2015
    At work
    What he said. Grab any easy to do tasks while you have it out. It can add a bit to the cost but absolutely worth it in the end
