#1
May 6, 2016
2016 wrx here.
Just put my Cobb Ap on, what do I need to monitor on my 6 gauge spots?
I'm familiar with the Cobb Ap, I use it on my other car.
Just don't know what parameters are important on this wrx...
Thanks!
sent from my phone...
#2
May 6, 2016
I cycle them around a lot but the ones I'm always watching are:
Fine knock learn
Feedback Knock
DAM
I sometimes monitor:
AVCS
Intake Temp / Intake manifold temp
Boost / Target Boost
Oil Temp
#3
May 6, 2016
What is the reason/purpose you would monitor AVCS phasing angle?
Sent from my SAMSUNG-SM-G890A using Tapatalk
#4
May 6, 2016
To verify that the ECU is fully learned after a map change or reset.
#5
May 6, 2016
(Edited)
Admittedly I don't have much knowledge if the new Hitachi ECUs, but the AVCS is not something that is learned typically. It's part of the map.
0
Reply
#8
May 11, 2016
I'm new to the WRX as well...2016 like yours. Coming from a mazdaspeed so I monitor the same basics I did with my speed.. Boost, Boost Target, Fine Knock learning, DAM, Feedback Knock and A/F Learning 1 which if I am correct is your long term fuel trims.
#9
May 11, 2016
Yep, AF Learning is LTFT and AF Correction is STFT. You got it
