hybrid build
Results 1 to 6 of 6
This is a discussion on hybrid build within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; so long story short my motor is gonna blow soon, I have the chance to get a ej257 block for ...
    Mar 2015
    hybrid build
    so long story short my motor is gonna blow soon, I have the chance to get a ej257 block for $175 dude said it was losing compression in one cylinder and thinks the rings are fried, if I decide to get the block what heads would I need and do they need machined to match the block ? and what other things would I need. I'm not looking to make crazy power probably 300 whp.
            MainFrame's Avatar
    Austin, TX
    You can use just about any phase 2 head, and you can choose to machine them or not.. it's all up to you, your goals, and your budget.
    Mar 2015
    I'm trying to build a reliable motor but also have some power will machining them make them more reliable because I heard they're prone to knock along with compression issues if you dont
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by mason04wrx View Post
    If you want to place priority on reliability and longevity, consider a lightly used OEM longblock. Built motors simply don't last as long as OEM counterparts in most scenarios.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
            MainFrame's Avatar
    Austin, TX
    There are a couple different ways to go about lowering the compression ratio ("hybrid" pistons, thicker head gasket).. Although in my opinion, machining the head chambers to match the volume and profile of the 2.5L STI head chambers would be the best way to go about it. I've done it using thicker head gaskets in the past and it worked fine, but my engine had other problems and eventually I went ahead and had the chambers worked over for the last build I had done.
    You never said what kind of car this is, but I'm assuming 2004 WRX.. the easiest (and cheapest) way to do it would be to have your existing ej205 (s20) heads rebuilt and chamber matched.
    I would go one step beyond that and suggest picking up a new ej257 shortblock from Subaru. You're looking at around $1800 out the door, and not have to worry about how it was treated in its previous life or if your machine shop/assembler messed up somewhere along the way.
