Nameless axelback and cobb catted downpipe?
Results 1 to 5 of 5
This is a discussion on Nameless axelback and cobb catted downpipe? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Hi guys, I'm just wondering if I were to buy the nameless muffler delete axelback exhaust and a cobb catted ...
    Sep 2015
    Hi guys, I'm just wondering if I were to buy the nameless muffler delete axelback exhaust and a cobb catted downpipe would the downpipe bolt on to the stock midpipe? If I remember correctly the stock midpipe size is 2.5in on a 2010 wrx and the cobb downpipe is 3in. Also would I be able to just use the stage 2 tune off the accessport with the cobb catted downpipe and nameless axelback? Thanks!
    Registered User Yoro721's Avatar
    Apr 2014
    Midwest
    Yes; Cobb's DP is matted to work with the factory midpipe (and midpipes larger than the 2.5" diameter), just remember to use your stock donut gasket. You may need a new one, and the average price is under $20. I am currently running a Grimmspeed Downpipe with my stock midpipe (had to get the adapter) with a Nameless track pipe, so it's very similar to the set up your inquiring about. perfect amount of volume without the drone. Good luck!
    2014 WRX 5DR Ice Silver Metallic. Cobb Short Shifter, Invidia Dual N1 CBE.
    Jan 2012
    New Jersey
    Genuine Subaru Downpipe to Catback Donut Gasket WRX STI Forester Legacy New | eBay New Doughnut Gasket - $16
    Grimmspeed Exhaust Adapter Flange 3" Downpipe to 2 5" Midpipe WRX STI | eBay Grimmspeed 3 to 2.5 adapter - $40
    Grimmspeed Downpipe to Exhaust 3" 2 Bolt Gasket 2X Thick for Subaru WRX STI EVO | eBay Exhaust Gasket - $21
    Grimmspeed 028001 2002 13 Subaru WRX STI Lgt Turbo to Downpipe Gasket | eBay Turbo Gasket - $21
    Then add a heat shield/exhaust wrap 40-80 or modify your own.
    I went with a CNT catted downpipe and so far so good.
    CFLip2x 2012 WRB WRX Build
    Apr 2014
    Midwest
    Quote Originally Posted by cflip2x View Post
    He doesn't need the adapter. Cobb's DP tapers down to 2.5
    Jan 2012
    New Jersey
    Quote Originally Posted by Yoro721 View Post
    Perfect even better.
    Well just in case another catted downpipe was chosen and the stock or SPT exhaust was used you may want to pick up the 3 to 2.5 adapter
