Recommendations for a boost controller....2012 WRX
Results 1 to 12 of 12
This is a discussion on Recommendations for a boost controller....2012 WRX within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I got a 2012 WRX with a few mods....Cobb intake, Invidia catted downpipe and catback exhaust, and a tune with ...
    Registered User SuperSonic12's Avatar
    Nov 2013
    Lehighton
    I got a 2012 WRX with a few mods....Cobb intake, Invidia catted downpipe and catback exhaust, and a tune with the Cobb Accessport. The next step I wanna go is for a boost controller but don't know much about them and which ones work the best so does anyone have any recommendations. I'm guessing using an electronic controller is what is mostly used anymore or works the best.
    Jan 2012
    New Jersey
    Grimmspeed
    2012 WRB 4DR | SPT Exhaust | Cobb Short Throw | Rally Armour | WC Lathe Werks Custom TI Knob | Kartboy Bushings | Stoptech Pads & Brake Lines | JBK Elements DRL | STI HID Retrofit | XB LED Angel Eyes | GrimmSpeed Lightweight Crank Pulley | Perrin Cold Air Intake
    CFLip2x 2012 WRB WRX Build
    A boost controller is a boost controller. Does the person tuning the car have a preference?
    Resident Tuner @ WTF Tuning
  5. #4
    Registered User Monk_Knight's Avatar
    Aug 2010
    Colorado
    Electronic is going to probably be your best bet unless you have a really specific reason for wanting a manual one. There are several that are well-known to be quality parts -- Grimmspeed's 3 port EBCS is one of the most popular. I have it myself and have been quite happy.
  6. #5
    Quote Originally Posted by Monk_Knight
    Better performance? An electronic solenoid will not touch the response of a quality MBC.
    If you want a set/forget option, EBCS is the way to go (e.g., you can not have to worry about things like temperature/altitude changes, assuming the compensation tables have been properly calibrated). If you want the best performance, MBC (but you need to be willing to adjust based on the environment you're currently experiencing).
    What about both (hybrid method)? You get the benefits of the MBC control at high throttle angles, and you get the ability via EBCS to use the compensation tables to account for the changes to environment.
    Based on the question, the OP will not be doing the calibration for the new boost controller; the person calibrating the ECU should be asked this question, and our opinions honestly mean squat.
  7. #6
    zax
    zax is offline
    Perverted Physicist zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    At the expense of a low-airmass vac leak...
    Zax's utterly unimaginably stock 2015 STi build thread
    Zax's Shaggin' Wagon Build Thread Now tuned for 99% pure Unicorn Jizz!
    Zach | Moderator | Builds, Electronics/Car Audio, Engine Modifications, Mid-Atlantic States, Suspension & Wheels, Tech & Modifying & General Repairs |
    Facebook me here
  8. #7
    Quote Originally Posted by zax
    There are pros/cons to every setup
  9. #8
    Nov 2013
    Lehighton
    Thanks for the feedbacks guys....this is my first turbo car and still learning the basics of how to make it run its best w/o losing power or damaging anything. well i have heard of the hybrid method from some others on here but wasn't sure of how it all worked and how much more effective it was. I like the thought of just being able to run it without having to get out and open the hood to adjust the MBC whenever I want to get on it. In a few months I plan on taking it to a professional tuner and put it on the dyno but haven't talked to anyone yet. So I should ask tuners what route I should take then?
  10. #9
    Registered User djk5077's Avatar
    Oct 2012
    Pittsburgh, PA
    I'd be curious to learn a bit more about this scenario. (i.e. any particular ill affects caused by the vacuum leaks, etc...)
    Considering I've seen the hybrid method recommended before, I take it the pros generally outweigh the cons in this case?
    - Dave
    2012 pbp WRX premium
  11. #10
    Village Idiot McBill's Avatar
    Sep 2013
    Buckeye State
    Quote Originally Posted by SuperSonic12 View Post
    Absolutely, ask the tuner that will be tuning your car.
    2011 WRB WRX Sedan - Q300, Invidia Catted Downpipe, Cobb RAM Intake w/Box, Tuned by Turn in Concepts
    Stink-Eye Mob #696
    Build Thread
    Facebook
    @billym14
  12. #11
    Some MBCs allow for a cabin dial so you can change it on the fly without getting out of the drivers seat.
    People have preferences. The tuner may have one.
  13. #12
    Mar 2015
    If u got the cobb acces port try the cobb ebcs it easy to install u get all the hardware n the acces port has a map for it u have to down load it but it is well worth it just make sure u run the vac lines right I had switched my intake n wastegate it took it to 22 psi
