new mods advice
Results 1 to 8 of 8
This is a discussion on new mods advice within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I had bought my WRX not knowing about the performance and how nice it can be tuned to... A rally ...
    Jun 2010
    new mods advice
    I had bought my WRX not knowing about the performance and how nice it can be tuned to... A rally beast! so as i was over seas i had learned some about what parts change are acute to each stage of tune. So recently i was out playing on some dirt roads, and after running a great ride, i had noticed a knocking. It scared the **** out of me and got it home as easily as possible. so i have a friend who is long time mechanic. He said there was a knock and seems to be coming from the turbo side of the motor and was not knocking faster with more throttle, just about the same rpm the turbo spools. So i assume a bearing has gone bad, so i was going to buy a rebuild kit. So i believe the stock turbo is a TD04L? and i have seen those and TD05's for reasonable prices. Should i go bigger?... Which leads me to my next thought..
    I had bought some parts while i was overseas so i plan on putting on a up-pipe and a turbo timer(if needed) new springs, and new front bumper, including putting a cold air on. Now i need to just get my car running to drive so the knock has to be fixed FIRST, which i think it is. But i was thinking if i was going in maybe put a few more parts in. So i been thinking getting the turbo back and new injectors with a new fuel pump. and a friend has a Cobb access port and i cant seem to find maps for the access port to work with what parts. Thank you for any advise as the love for DSM's has inflated to ... ahhhhh wow, well thats best i got, but thank you really
    The Jedi Ninja TownLine500's Avatar
    Oct 2013
    Boston
    Welcome!
    What is your car?
    Year/Model? What mods are one it?
    It sounds like rod knock, but it's very hard to tell with limited info.
    Fill in the blanks, and our senior members can point you in the right direction.
    STINK EYE MOB #500
    2009 Subaru Impreza (I bought it new for my Mom)
    2004 Subaru WRX (Sold)
    2013 Subaru WRX Premium
    1996 Honda Civic Lx
    WRX genuine Face Ripping ACCELERATION!!!
    My Boston Beat Down Build Thread
    http://www.clubwrx.net/forums/builds...wrx-build.html
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    You need to bring your car to a mechanic that can tell you exactly what is wrong with your car, not just what might be wrong with your car. If you just guess and then start buying parts you will be throwing money at it. As TL says above, let us know model/year/mods and we can help you out. BTW, you don't need a turbo timer.
    Village Idiot McBill's Avatar
    Sep 2013
    Buckeye State
    Quote Originally Posted by TownLine500 View Post
    If it's coming from the passenger's side, and is not in synchronization with the rpms, then it's likely not rod knock and could be something with the turbo as OP said.
    OP, let it be known that if you upgrade the turbo that's not the only expense incurred. With a bigger turbo you will likely need a more efficient intercooler, some bigger injectors, possibly a fuel pump, and likely some other parts I can't think of off the top of my head. It's not just a bolt a go process.
    Also, it's no surprise the AP doesn't have maps supporting you mods list, as the only parts that are supported by Cobb are those to go with an intake and a turbo back exhaust.
    Billy
    2009 Ducati Monster 1100
    2008 Legacy 3.0R - SOLD
    2011 WRB WRX Sedan - SOLD
    Stink-Eye Mob #696
    Facebook
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Jun 2010
    Thank you for the welcome... sorry i forgot the most important info, i have a 05 wrx not sti unfortunately. i have installed the cold air on and had taken it to a guy with a programmer for reading codes and such, and had it running back to normal.
    Now i do believe it is the turbo that has the "knock" because its almost as u can feel it from there when your under the hood. Also my Mechanic is my father in law that has a very reputable rep, but thats beside the fact. I have wrenching on things all my life, just not a pro...
    Also i understand that changing my turbo is not just a bolt on, but i have no tuner shops with in 300 miles. thats why i was wondering about the access port.
    Also with the purchising the new turbo, i was going to complete the exhaust out... also thinking of new injectors and pump.
    BUT should i just rebuild my stock turbo or get a new bigger one?
    Nov 2012
    Anything above a stage 2 set up (down pipe) and an intake you will need the car to be professionally turned to run optimally. You can either drive to a tuning shop, or get an E-tune. If you do indeed have an issue with your turbo, I would get a stock location OEM spec turbo replacement. If you are going to replace with a higher performance turbo you will want to add a lot of supporting mods (better intercooler, larger injectors, higher flowing fuel pump, recommended forged internals, etc.). This will be a very pricy undertaking. If you want a recommendation, bring the car to someone that can tell you EXACTLY what is wrong with it (I mean no offense by this statement, but you need to know what is wrong with your car - an individual that has experience with suabrus is the one to go to). Fix it. Then if you want more power go for the high flow down pipe, intake, access port, or tactrix cable and tune properly. If that is not enough power, then go from there. I would make certain the car is up to date maintenance wise, then get a compression/leakdown test done, and make any fixes prior to additional modifications before you move forward with performance mods.
    This is a good thread if you haven't read through it yet --->First Modifications - what to do and not to do
    something else forever Germz to Japz's Avatar
    Jul 2014
    Herndon Virginia
    2005 wrx's look sick, congrats and welcome
