Custom Fab Recirculating Downpipe Question
Results 1 to 14 of 14
This is a discussion on Custom Fab Recirculating Downpipe Question within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I am going to my fabrication guy tomorrow because I have grown somewhat tired of the sound from my 44mm ...
    Dec 2014
    I am going to my fabrication guy tomorrow because I have grown somewhat tired of the sound from my 44mm wastegate and dump tube. I will be converting to a recirculating down pipe. My question is if anyone has recommendations as to how and where the piping should be welded. I am confident in my fabricators work, however I always find it helpful to have suggestions from those who have had experience with the same work. I have done some searching on various forums and I've found that it seems the tubing should come in around 18" back from the turbo but what I could not find is where exactly on the down pipe it should be welded in. I can imagine that if done incorrectly it could disrupt the flow of exhaust gases. If anyone has any pictures or advice on the situation I would greatly appreciate it.
    Thanks
    zax
    zax is offline
    Perverted Physicist zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    As far downstream as possible.
    Zax's utterly unimaginably stock 2015 STi build thread
    Zax's Shaggin' Wagon Build Thread Now tuned for 99% pure Unicorn Jizz!
    Zach | Moderator | Builds, Electronics/Car Audio, Engine Modifications, Mid-Atlantic States, Suspension & Wheels, Tech & Modifying & General Repairs |
    Facebook me here
    Moderator Donkey's Avatar
    Da boonies,Va
    The angle it comes in at as well will make a difference. I would say you would want it 30 or less. But honestly an easier way to deal with it is just weld on a "mini" muffler to the EWG dump tube.
    2002 FORESTER S
    1998 FORESTER S
  5. #4
    Dec 2014
    Perhaps I'll go the mini-muffler route, seems to be a less complicated solution
  6. #5
    OMG WTF MainFrame's Avatar
    Texas, United States
    Quote Originally Posted by thump88 View Post
    Supertrapp
  7. #6
    Da boonies,Va
    Supertrapp
    Yup...
    2002 FORESTER S
    1998 FORESTER S
  8. #7
    Dec 2014
    Muffler seems ideal. I'm going to order one over the weekend. Once I have it set up, I'll post a before/after video. Thanks for all the help and comments.
    Stay tuned...
  9. #8
    Aug 2012
    Tucson, AZ
    Mmmm invidia ewg muffler? Lol. Would sound sick
    Stinkeye member 520
  10. #9
    Dec 2014
    Installed my Supertrapp yesterday, amazing customer service from Summit Racing, received the product the next day, even with ground shipping! Chopped the muffler down a bit in size and took about two inches off the dump tube. This allowed the muffler to be flush with the lowest part of my down-pipe so there was no compromise to ground clearance. Cutting it down a bit also eliminated movement from the additional weight of the muffler.
    Review:
    I am very pleased with the results, it is significantly quieter than before. Of course, the waste-gate is still audible, but it no longer sounds like the finale of a Hell's Angels Bike meet. I left all 12-discs in for now, down the line I may toy with adding or removing some to examine the difference in sound. For now, I'll just leave it the way it is. I have attached a few pictures and a "Before & After" video. I truly believe the video does not do the muffler justice, but it gives you an idea. I also run a Perrin exhaust which is so quiet that anything can be heard over it.
    Thanks for all the suggestions and help!!!
Name:	Dumptube with muffler.JPG
  11. #10
    Registered User 100plus2Vegas's Avatar
    Mar 2014
    Oceanside,Ca
    Saw your post on So Cal Subies, but video wouldn't work. It works on here. It sounds really good.
    Having it open like that, do you get fumes inside?
    14 sedan Limited: AEM intake, Tomioka IC hose, Cobb AP V3, Invidia catless down pipe, custom 3" mandrel bent single exhaust, Aem air fuel gauge,Cobb knob,Perrin Pitch Stop mount, SPT front strut tower brace, K-Sport coilovers@1.5" drop.
    07 Duramax LBZ- 26psi,intake, TBE, Diablosport programmer, Edge Insight with EGT, EGR block off, BD exhaust manifold, PPE fuel valve.
  12. #11
    zax
    zax is offline
    Nov 2008
    By the time the wastegate is open, the car is accelerating fast enough that the fumes would be wicked away from the car quite easily
    Facebook me here
  13. #12
    Dec 2014
    Nope, never had any issues with fumes inside the cabin!
  14. #13
    Thanks for the sound clips.. I've been considering adding a muffler to my EWG for a while.
    Sounds like it knocked the volume down quite a bit, without changing the tone too much.. perhaps a little less raspy, but that's about it.
  15. #14
    Dec 2014
    What I really noticed is the muffler took the throaty, kind of thudding note out of it. You can still hear the "rattlesnake shake" but it is significantly quieter.
    I would assume with a slightly louder exhaust (louder than the one I have), the dump would be almost inaudible.
