NO BOOST 2011 WRX?!??!?!?
Results 1 to 3 of 3
This is a discussion on NO BOOST 2011 WRX?!??!?!? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Today i was driving my 2011 wrx sedan, i was driving hard and everything was okay and all of a ...
    Dec 2013
    Toronto, Canada
    Today i was driving my 2011 wrx sedan, i was driving hard and everything was okay and all of a sudden after i turned a corner i lose all boost and for some reason there is little to no noise coming out of my exhaust. No exhaust pressure. My COBB boost controller is reading around 2-3 psi at around 4000rpm.
    My mods: Cobb Air intake with a stage 1 tune (91 octane) Invidia Q300 Catback
    Also: A bracket broke on one of my cats causing it to rattle, i didnt fix it could've broke on the inside?????
    Tried Re-Mapping, didn't work, No check engine.
    Right before 100k KMS so I'm still covered under warranty
    ANY IDEAS WHATSOEVER AS TO WHAT THIS COULD BE ???
    OMG WTF MainFrame's Avatar
    Texas, United States
    What is your DAM at?
    A rattling bracket technically could cause your ECU to go into limp mode and pull boost if it's reading enough false knock.
    Registered User 100plus2Vegas's Avatar
    Mar 2014
    Oceanside,Ca
    Do you have a check engine light on with flashing lights?
    When I got my po244 overbooost code, I was under heavy acceleration up hill when the fuel cut and lost power.
    If not, check your vacuum lines.
    14 sedan Limited: AEM intake, Tomioka IC hose, Cobb AP V3, Invidia down pipe with 3" cat, custom 3" mandrel bent single exhaust, Aem air fuel gauge,Cobb knob,Perrin Pitch Stop mount, SPT front strut tower brace, K-Sport coilovers@1.5" drop.
    07 Duramax LBZ- 26psi,intake, TBE, Diablosport programmer, Edge Insight with EGT, EGR block off, BD exhaust manifold, PPE fuel valve.
