I will be installing a SPT exhaust this weekend on my 13 WRX sedan. I only have the donut gasket (PN 440022AA123) and screws. I am missing the gaskets for in between the mid pipe and mufflers. Does anyone have a part number for these gaskets or a viable alternative (gasket maker ) ?
Thanks for your input but I did come across that thread. I just need either the part number for the gaskets that fit between the muffler and mid pipe or is there another method I can use to make a solid connection. I was hoping to not spend $65 for the hardware kit as I already have the screws and donut ring gasket.
I hope this helps. I had an spt catback on my 13 Wrx hatch, I don't know if the mid pipe are quite differnt compared to the hatch but in the spt mid pipe I had it had a gasket that was actually welded on to the mid pipe so there was no need for a gasket due to the mid pipe changing from a 2.5 to the 3 inch exhaust. When I installed my old spt on a friends 11 STi there was no exhaust leak what so ever. So when you do get it take a look and hopefully it has one on it.
