Invida V2 DP
Results 1 to 4 of 4
This is a discussion on Invida V2 DP within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I had a question on if its even worth wraping a DP, ive read people say no unless ur going ...
    Aug 2014
    Beaufort, South Carolina, United States
    Invida V2 DP
    I had a question on if its even worth wraping a DP, ive read people say no unless ur going over 400HP (Which deffinately wont happen in the near future) but also Im reading people saying its a must do. Anyone have any suggestions?
    Registered User subypete's Avatar
    Jan 2008
    Forsyth, IL
    I wrapped mine to protect my CV axle boot and keep my underhood temperature down. Even then, I only wrapped it about halfway down. There really is no reason to wrap it past the point it is out of the engine bay. Remember, the stock DP came heat shielding - on a car that had presumably less power than a car tuned for a DP - and thus emitted less heat. Like I said, without the wrap you can cook your CV boots pretty quick - next thing you know you'll have grease all over your DP... hot grease = lots of nasty smelling smoke.
    2013 Nissan Leaf SL - Extra Leafy
    2002 OBP WRX - Stage II - "Black Betty" - SOLD
    1987 Subaru GL Wagon - Stock - "Mr. Ratburn" - SOLD
    MTM
    MTM is offline
    Registered User MTM's Avatar
    Feb 2014
    NorCal
    Im going to ceramic coat mine. I should have done it before I installed it but I didnt. Ill have to take it off and do it soon though. Too bad youre not closer or I would have done yours too. Im pretty cheap.
    Registered User 100plus2Vegas's Avatar
    Mar 2014
    Oceanside,Ca
    If anything I would ceramic coat it. Wrapping the pipe can cause premature failure of the tubing over time.
    On the older wrx's, the down pipe ran closer to the firewall and that rubber piece coming out of it.
    On my 14, there is plenty of room all around it, plus I'm running the Cobb heat shield. I'm not concerned.
    14 sedan: Protune: 318AWHP 344ft lbs up pipe, Tial EWG, AEM intake, Cobb AP V3, 3" TBE, Avo FMIC, Turbo Smart bpv, Aem air fuel gauge,Cobb knob,Perrin Pitch Stop mount, SPT front strut tower brace, K-Sport coilovers@1.5" drop. Eibach sways, Perrin Spherical end links, Cusco subframe brace, White Line sway braces, Perrin sub frame bushings.
    07 Duramax LBZ- 26psi,intake, TBE, Diablosport programmer, Edge Insight with EGT, EGR block off, BD exhaust manifold, PPE fuel valve.
