Stage2
Results 1 to 8 of 8
This is a discussion on Stage2 within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Hi! Im looking to find out how long and how well has your stage2 setup performed? How many miles since ...
    The Jedi Ninja TownLine500's Avatar
    Oct 2013
    Boston
    Stage2
    Hi!
    How many miles since the stage2 upgrade?
    What seems to be the average life of stage2 tuned engines?
    How does your car perform?
    I'm gathering peoples thought and experiences with your stage2
    Any input is welcome (constructive please) thoughts and opinions.
    STINK EYE MOB #500
    2009 Subaru Impreza (I bought it new for my Mom)
    2004 Subaru WRX (Sold)
    2013 Subaru WRX Premium
    1996 Honda Civic Lx
    WRX genuine Face Ripping ACCELERATION!!!
    My Boston Beat Down Build Thread
    http://www.clubwrx.net/forums/builds...wrx-build.html
    STinfection WRX-maniac's Avatar
    Sep 2013
    Western Maryland
    Quote Originally Posted by TownLine500 View Post
    Hi!
    I went stage 2 at about 27k miles, performance is great!
    I have about 7-8k miles on my car now since I have went stage 2, no issues as of yet
    This all depends on you! stage 2 is considered to be reasonably safe. Be sure if you are using an OTS map to do plenty of data logs and make sure your car took to the tune and everything is running within the parameters is should. If you do that and get map revisions as needed, there is no reason it shouldnt last a long time.
    Car runs amazing, powerband is much smoother and lasts longer. I'm tuned at stage 2 at 18.5psi and have seen peaks in the upper 19's. Amazing is really the only word that comes to mind over stock!
    Good luck when you decide to go stage 2! It is worth it as the power really goes up after the downpipe and tune. Do your research!
    Stink-Eye Mob #301
    2012 WRB STi Limited Sedan
    2011 WRB WRX hatchback---Retired and traded.
    http://www.clubwrx.net/forums/builds...sti-build.html <---- My STi build thread
    http://www.clubwrx.net/forums/builds...ld-thread.html <----My WRX build thread
    Oct 2013
    Boston
    I already have a stage2 tune. I'm looking for how long people have ran there set up for?
    In terms of time and miles. How reliable has your car been?
    I'm looking for opinions just like WRX-maniac has provided (Thanks for quick response)
    Any constructive info would be appreciated.
    STINK EYE MOB #500
    1996 Honda Civic Lx
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    Take everything commented here with a huge grain of salt. There are multiple environmental factors that weigh more heavily on an engine's lifespan than just saying, "I went Stage II, runs fine".
    In my opinion, questions like this are pretty useless, since there are so many variables to consider. I can say that my specific setup worked great for my car, but if you copied what I did, who knows how well it would work? Also, nobody here can tell you how long a Stage II engine will last. If you're redlining the car from every stoplight, obviously that's going to have a more significant impact on lifespan than a conservatively-tuned car driven carefully.
    With that preface, here's my answer with as much detail as I can muster:
    Car: 2003 WRX. Installed hardware and tune at 95k miles
    Hardware: Cobb catted downpipe, factory midpipe, STI axleback. Grimmspeed catless uppipe. AEM wideband O2 sensor installed in downpipe bung. Custom Stage II tune.
    Reliability: The car ran fine until it was totalled. I have datalogs proving the engine was responding very well to the added power, with no red flags on the later map revisions. Credit to WTF Tuning for a very solid and well-balanced base map to start from.
    Notes: The car was well-maintained and all stock when I bought it. No previous engine/drivetrain abuse that would expose itself under added strain. The car was fully serviced to factory specs before doing any modifications.
    The car was a joy to drive. Matt and I focused on smooth power delivery, not peak horsepower. I have no idea what the dyno numbers would have been, and I honestly don't care. I only used the car for commuting, and didn't drive it like an asshat, so I have no reason to think it wouldn't have lasted for many years to come.
    2007 Outback 3.0R wagon
    Moderator Donkey's Avatar
    Da boonies,Va
    Quote Originally Posted by Rambo View Post
    /\ This.
    2002 FORESTER S
    1998 FORESTER S
            MainFrame's Avatar
    Austin, TX
    I ran an Access ECU stage 2 tune on my bugeye for about 70k miles, never had a problem with it.. other than the tune being ridiculously rich. Performance felt like it was how the car should have come from the factory.
    Oct 2013
    Boston
    Thanks guys.
    This is exactly what I was looking for. How peoples cars are set up, and the longevity of the engine. I don't race my car or drive it hard, I just play around sometimes. Anyone else's input or insight would also be helpful. Come stage2 people lets hear your experiences and story's.
    STINK EYE MOB #500
    1996 Honda Civic Lx
    Palmyra, NJ
    Same...every Stage 2 is just that bit different...OTS Stage 2 tunes are a good bump in performance, yet are generic enough that they can be used on most cars without issue.
    In theory you should be perfectly fine with it as long as you don't beat the piss out of your car, and obviously as long as the tune is reputable (such as in the case of a protune).
