filled up with 88 gas
Results 1 to 9 of 9
This is a discussion on filled up with 88 gas within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; when idling at a light on the way home i kind of heard a thumping or maybe even a knocking. ...
    Aug 2014
    when idling at a light on the way home i kind of heard a thumping or maybe even a knocking. what should I do at this point? granted vehicle was kept below 3.5k rpm
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Run down the tank of gas while staying out of boost. Put at least 91 in next time and all other times.
    STinfection WRX-maniac's Avatar
    Sep 2013
    Western Maryland
    THIS. It even says on the gas door to run premium fuel only. (i.e. 91 or 93 octane) If you have never owned a vehicle like this then you should have read the manual which also very clearly states what fuel to use. The ONLY time I would run anything lower than 93 (what im tuned for) is if it was an emergency situation where i needed gas and there was no 93 around. In that case, put in the highest octane available there, and just enough to make it to the next gas station where they have the fuel you need, and as 11blackSTi said, stay out of boost while running it.
    Stink-Eye Mob #301
    2012 WRB STi Limited Sedan
    2011 WRB WRX hatchback---Retired and traded.
    http://www.clubwrx.net/forums/builds...sti-build.html <---- My STi build thread
    http://www.clubwrx.net/forums/builds...ld-thread.html <----My WRX build thread
    Aug 2014
    got it. thanks.. I had someone else put the gas for me and I told them 91 or higher and when I looked at the receipt later on I saw that it was 88.
    The Jedi Ninja TownLine500's Avatar
    Oct 2013
    Boston
    As funny as this may sound. Pump your own fuel wherever possible, that way you are always sure what grade the gas is. Unless you live in Oregon where I've heard pumping your own gas is illegal.
    And if you do go to full serve station, watch the attendant to make sure they are using 91 or 93 octane.
    STINK EYE MOB #500
    2009 Subaru Impreza (I bought it new for my Mom)
    2004 Subaru WRX (Sold)
    2013 Subaru WRX Premium
    1996 Honda Civic Lx
    WRX genuine Face Ripping ACCELERATION!!!
    My Boston Beat Down Build Thread
    http://www.clubwrx.net/forums/builds...wrx-build.html
    Registered User Goose42's Avatar
    Jun 2014
    PNW
    Correct, we are not allowed to pump our own gas, though most attendants allow me to with my bike. I ALWAYS watch them to make sure they use premium, often wonder though how careful they are when removing the nozzle. I go to the same station, they all know my car so I can only trust... FWIW, I would not even let my wife take my car to get it filled!
    Or he is rolling down the street in his new slammed ride vaping out the window, enjoying the tow truck ride. - XJman
    2017 ISM Impreza 5MT Hatchback Sport
    2015 WRX COBB Surgeline Stage 2 Pro Tune (Sold)
    Journal-
    http://www.clubwrx.net/forums/builds...ml#post3579257
    Feb 2013
    Salem, VA
    Toss in a bottle or two of octane booster, it may help some while continuing to stay out of boost.
    '02 Midnight Black Pearl WRX wagon, 5-speed 216k miles
    factory short throw, triple gauge pod, premium sound
    Mishimoto radiator, Perrin inlet, H6 rear
    Jun 2012
    Boca Raton, FL
    If the car is stock, it will run done on 88, if tuned, follow advice above and stay out of booth until you can run dow n the fuel and fill up with proper fuel
    Aug 2014
    Thanks guys I got it sorted it, did exactly as you said and it worked out good. Hard lesson to learn ill always put my gas from now on
