Turbo replacement?
Results 1 to 4 of 4
This is a discussion on Turbo replacement? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Hey hows it going I have an 04 wrx wagon with around 135k miles. I was thinking about replacing the ...
    Aug 2014
    Beaufort, South Carolina, United States
    Turbo replacement?
    Hey hows it going I have an 04 wrx wagon with around 135k miles. I was thinking about replacing the turbo because I feel like its time since the miles are starting to add up. I would like a turbo better than the stock TD04 but im not looking for crazy power. My goal range is around 350HP. Any suggestions on what turbos to look for or what you guys have used that works well would be great. I was reading about going to a vf35 which I believe is the STi's turbo, also what supporting mods do you guys recommend to run with an upgraded turbo?
    Moderator Donkey's Avatar
    Da boonies,Va
    Mileage alone is not reason to replace a turbo and you cannot upgrade the turbo without upgrading the injectors,fuel pump and retuning the ECU at a bare minimum. The VF35 is not a USDM Sti turbo and is going to be hard to find as well as expensive. The VF39, VF43 and VF48 are much easier to find.
    2002 FORESTER S
    1998 FORESTER S
    Jan 2012
    New Jersey
    Do you have any other mods on the car?
    CFLip2x 2012 WRB WRX Build
    Registered User 02_Subie's Avatar
    Jun 2014
    SE Iowa
    I would reccomend a Grimmspeed boost control solenoid if you still have your oem one.
