Cobb down pipe
Results 1 to 9 of 9
This is a discussion on Cobb down pipe within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Purchased Cobb down pipe, one suggested by rally sport direct, same time I purchased Invidia N1 catback exhaust. Exhaust has ...
    Feb 2014
    Southern New Hampshire
    Cobb down pipe
    Purchased Cobb down pipe, one suggested by rally sport direct, same time I purchased Invidia N1 catback exhaust. Exhaust has been installed
    Haven't done any other mods yet, but will be putting top mount inter cooler and cold air intake soon.
    Question is.....any disadvantage to installing down pipe on car now? Any advantage?
    Thank you in advance
    2014 DGM WRX premium sedan
    Registered User fireguy220's Avatar
    May 2014
    Akron, ohio
    Not sure the advantages or disadvantages but make sure you tune it before you install the dp if you haven't already.
    Feb 2014
    Quote Originally Posted by fireguy220 View Post
    Yeah been on line with rs direct. Accessport or pro tune?
    Thinking should go with pro tune
    May 2014
    Akron, ohio
    I'd go with an Cobb ap v3 easy functionality and very user friendly. I'm not to sure about the pro tune though.
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Quote Originally Posted by Run amok View Post
    There is a disadvantage to installing the DP now. That is that it would be very bad for your car, as you have no way of tuning for it. Your car needs a tuning solution, whether that be a cobb access port, or a tactrix cable. You will need one or the other regardless of if you use off the shelf tunes, or get a pro-tune/e-tune. The tactrix is cheaper, and you can do open source tuning using the cable (you need a laptop too). The AP is a handheld easily used device, that is convenient, and doubles as a gauge. I would suggest researching both and deciding what route you want to go. To be honest, a pro tune at this point is not really worth the money unless you want to stop at stage 2, which in that case, the pro-tune is the way to go. A pro-tune is always better than an off the shelf map as it is designed specifically for your car. But if you are planning on further mods, which is sounds like you are, then I would recommend waiting until you get at a point where you "outgrow" the off the shelf maps, and at that point get the pro-tune.
    Regardless of which tuning route you go (I mean cobb AP or tactrix/opensource), you should perform data-logging to ensure your tune or "Map" is functioning the way it should. There are people here that can help you look at that.
    Registered User Aaronw9's Avatar
    Oct 2012
    Seattle
    Downpipe and tune need to be at the same time. Also get a cobb or aem intake if your going the AP route because those are the only intake's that work with the AP maps.
    The Jedi Ninja TownLine500's Avatar
    Oct 2013
    Boston
    I personally use a Cobb AP. I have the ots maps and 2 custom protune maps. It is great to be able to datalog tune and act as a gauge. It's also small and ultra portable vs laptop. I do a good amount of data logging and monitoring to make sure my car is happy. I've had 2 WRXs and 2 Cobb tuners, I've had great experiences with them and I'll continue to use them. Just my 2cents.
    STINK EYE MOB #500
    2009 Subaru Impreza (I bought it new for my Mom)
    2004 Subaru WRX (Sold)
    2013 Subaru WRX Premium
    1996 Honda Civic Lx
    WRX genuine Face Ripping ACCELERATION!!!
    My Boston Beat Down Build Thread
    http://www.clubwrx.net/forums/builds...wrx-build.html
    Feb 2014
    Quote Originally Posted by TownLine500 View Post
    Thanks all. Sounds like I might want to do Accessport and after done all mods maybe pro tune. Appreciate all input
    Registered User EndlessSea's Avatar
    Nov 2012
    Las Vegas
    you're not driving around on the stock tune with a full turboback are you?!
    2013 wrx sedan(saving up for a 2015 STI)
    Previous faist cars: '05 Mustang GT '02 RSX-S, '91 SR20 240sx, '85 300zx turbo
