Up pipe installed
Results 1 to 5 of 5
This is a discussion on Up pipe installed within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Hello all, not sure if this is the appropriate place to post this, but I wanted to give my impressions ...
    Registered User TURBOTOM2010's Avatar
    May 2009
    Up pipe installed
    Hello all, not sure if this is the appropriate place to post this, but I wanted to give my impressions of the product, install, and performance.
    I got an Invidia pipe from RSD. It is great quality and all studs and threads were fine. It took a cleaning to get the grime out from inside the pipe though.
    The install was done in my garage on a hot Florida August day. It took me 4 hours from jacking to lowering. It did help to research photos and videos of the install. The up pipe thread on here under tutorials was a big help. Youtube was good too.
    I capped the O2 with the one from Invidia.
    Upon starting, I heard a deeper burble to my stock exhaust. I got no CELs either. Driving it was the greatest reward. The throttle felt lighter and much more responsive. Boost came on earlier, and there is a better seat of the pants feel.
    Definately worth the 4 hours spent.
    I have an SPT intake and now the pipe. Next I hope to get an AP and DP. Then exhaust, then bigger FP, injectors, turbo, TMIC....See, that's how it all starts, with one bolt on to another, lol!
    Registered User 02_Subie's Avatar
    Jun 2014
    SE Iowa
    I have also been pleased with my invidia uppipe! The bung you plugged with the bolt from invidia is for the EGT sensor, so you may get a check engine light from this being unplugged. If you do, placing a 2.2K Ohm 1/2watt resistor in the EGT plug will get rid of it.
    May 2009
    Ah, ok EGT sensor. Yeah, no CEL yet, but I'll get the 2.2 if so. I like that I did the hardest(?) mod first, and everything else will be easier from here on out. The DP will be easy, and the other parts I listed. The turbo, when done, may be difficult. I'll find out!
    I'm still loving the car every time I drive it, not missing my Mustang yet, haha!
    Registered User SubaruWRXJosh's Avatar
    Jul 2014
    MA
    Congratz on the successful install!
    2013 Subaru WRX Premium
    Torqued Performance Stage 2, Invidia Catless Downpipe, Tomei Equal Length Headers, Cobb EBCS, Group N Motor Mounts, Perrin Transmission Mount, Perrin Pitch Stop Mount, Hood Scoop Fins, Kartboy Short Shifter, Kartboy Front & Rear Shifter Bushings, Perrin Heat Shield, STRi 52mm Amber Boost Gauge, SMY ClusterMaker Pod, Rally Armor Mud Flaps, Subaru OEM Black WRX Ornaments
            MainFrame's Avatar
    Austin, TX
    It only gets easier, before it gets harder.. much harder.
