Heat shielding
Results 1 to 11 of 11
This is a discussion on Heat shielding within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Hi!: I was looking to see if anyone has any experience with DEI reflectagold. I'm thinking of lining my GS ...
    The Jedi Ninja TownLine500's Avatar
    Oct 2013
    Boston
    Heat shielding
    Hi!:
    I'm thinking of lining my GS heat shield with it. And maybe the part of the DP in the engine bay.
    Has anyone done this before? This stuff says its good to 800 degrees. Does the down pipe even get that hot under normal driving conditions? Any input would be appreciated.
    STINK EYE MOB #500
    2009 Subaru Impreza (I bought it new for my Mom)
    2004 Subaru WRX (Sold)
    2013 Subaru WRX Premium
    1996 Honda Civic Lx
    WRX genuine Face Ripping ACCELERATION!!!
    My Boston Beat Down Build Thread
    http://www.clubwrx.net/forums/builds...wrx-build.html
    Oct 2013
    Boston
    Hi!
    Has anyone had any experience with DEI reflectagold?
    Looking for opinions, any input will be helpful.
    STINK EYE MOB #500
    1996 Honda Civic Lx
    ClubWRX.net Vendor WTF Tuning's Avatar
    Feb 2014
    It would be worthwhile to put on the TMIC, but on the downpipe, you want exhaust wrap.
    Instead of wasting any time with the heatshield, get a turbo blanket.
    Apr 2004
    Southeastern PA
    Quote Originally Posted by WTF Tuning View Post
    Agreed. The gold stuff is limited to what it can do under the hood. I did a DIY turbo blanket that seems to be working very well.
    Mods & Pics
    Oct 2013
    Boston
    I have a ptp turbo blanket. I have seen pictures with the Cobb or Grimpeed heat shield lined with DEI reflectagold. I'm wondering if gold liner with turbo blanket and heat shield might be over kill. Or may even cause coolant over heat? It looked good in pictures but I'm not so sure now. I also thought of lining the Cobb air box on the outside facing engine, I have also see quite a few pictures of them lined. And Sasquatch do you have a heat shield over your turbo blanket? If so what make or brand?
    STINK EYE MOB #500
    1996 Honda Civic Lx
    Apr 2004
    Southeastern PA
    Quote Originally Posted by TownLine500 View Post
    Yes, it is a custom fit / cut wrap using a Thermotec kit. I have a post or two on it - I'll see if I can dig them up. The heat shield is by Cobb - very similar to the GrimmSpeed. I'm thinking the gold stuff might prevent the heat shield from doing its job, namely absorbing and dissipating heat. Zax is our resident guru on the subject ...
    Here it is: Fuel pump, injectors, TGV deletes and TD04 19T
    This became a very lively discussion thread chock full of good info that went way beyond the install.
    Mods & Pics
    I wouldn't bother with a heat shield, then...it's really not doing much of anything at that point, if you have the blanket on there. At least, I wouldn't purchase an aftermarket unit; if anything just use the stocker if you want to "double up", but it really only makes it one more thing you have to remove/replace every time you have to work in there.
    Resident Tuner @ WTF Tuning
    Oct 2013
    Boston
    Quote Originally Posted by Sasquatch View Post
    Thanks for the info thread. It was very informative and even answered several other questions that I had. A question for you. Did the combination of turbo blanket and heat shield combined, ever cause your coolant to over heat on hot days? Or did the coolant just get a bit warmer? And also how long did you run that setup for?
    STINK EYE MOB #500
    1996 Honda Civic Lx
    Oct 2013
    Boston
    Changed my avatar picture to my old car. Look familiar Sasquatch?
    STINK EYE MOB #500
    1996 Honda Civic Lx
    Oct 2013
    Boston
    Update.
    I ended up with GrimSpeed heat shield over my ptp turbo blanket. Looks sharp. I lined the outside of Cobb air box with reflectagold. Left top plate black. You can barely see the gold and seems to be providing good heat dispersal. Plus it looks SWEET!!
    STINK EYE MOB #500
    1996 Honda Civic Lx
    Apr 2004
    Southeastern PA
    Still have that setup. Never a problem with coolant getting too hot. I doubt a wrap could cause that.
    Ah yep, 'cept I left the side skirts black. Matches the tires nicely.
    Mods & Pics
