Intercooler questions - Page 2
Results 16 to 30 of 36
This is a discussion on Intercooler questions within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I went with Process West. Comes with everything you need including a hood scoop splitter. Read on: http://www.clubwrx.net/forums/engine...led-9-4-a.html...
    Apr 2004
    Southeastern PA
    Mods & Pics
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Justin, you are not getting this. Heat flow goes both ways! If it dissipates heat faster, that also means it absorbs heat faster. This is physics!
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    There is no thermal equivalent then to a semiconductor in electronics? Where heat travels one way only?
  6. #19
    zax
    zax is offline
    Nov 2008
    OK, yes. I greatly simplified the statement. Yes of course heat pumps and TECs (Peltier effect) allow heat to travel in one direction. Obviously not all thermal processes are reversible...
    Facebook me here
  7. #20
    Ok sure for Peltiers but those are active. It'd be neat to have a passive sturdy material to make one-way heat conductors of sorts.
  8. #21
    zax
    zax is offline
    Nov 2008
    Honestly... Am I missing something? I'm a little rusty on my condensed matter and material physics, but I can't think of any passive material that has one-way heat transfer properties...
    Edit: holy crap did not know this: http://www.popsci.com/science/articl...-one-direction
    Double edit: I AM rusty, because this should violate entropy. Now I'm digging into sections of my brain I haven't used in a while...
    Facebook me here
  9. #22
    Jun 2014
    Meriden, CT
    Subaru WRX/STI Performance Top-Mount Intercooler Kit, 2002–2007
    This is the intercooler i was thinking about getting. Does anyone a have/had one that could tell me how they like/liked it?
  10. #23
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by TylerPedro View Post
    Mishimoto has been making cooling cores for years, but is very new to the air-air intercooler game for Subarus. Not to say that the TMIC isn't any good and I suppose I'd trust Mishimoto over any startup company, just I have no supporting data...
    Facebook me here
  11. #24
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by MTM View Post
    Cerakote Coatings: C-187Q Transfer Grey (Air Cure)
    Ill find links that actually support me later if you really want me to. Notice I said thats not true about black but then said especially with heat dissipation coatings... liiiiike what I just linked. They have researched it and Ill have to find the data sheets and stuff. But yeah its about color somewhat but its also about the material you are using. The example I used it gray, and not black.
    So you're saying painting it black will REDUCE it's ability to transfer heat? Because I was saying it would increase it's ability to transfer heat, which will cause it to heat soak even worse.. since when the car isn't moving the air outside the intercooler will obviously be hotter than the air inside it.
    Mighty Car Mods did a youtube video on this recently that showed painting a TMIC black would be a bad idea..
  12. #25
    Jun 2014
    Meriden, CT
    In your opinion what would be your next 500-1000$ upgrade? I only have the cobb accessport running stage 2, an invidia bellmouth catless downpipe and blitz nur spec cat back. I was thinking maybe a blow off valve and intake? Or maybe brakes? I have brand new 17x7.5 rims with no tires, maybe put tires on them? Id like to see from people who know more than me what the best bang for my buck would be. Also im not too familiar with the accessport. Can i get a brief description of exactly what i have the ability to do with it. I dont know if i need to make adjustments with cpu or what. Teach me well!!
  13. #26
    Registered User A265's Avatar
    Mar 2009
    in a igloo
    Good sticky summer tires, they are the most important factor for handling and braking. Also since you have a 2.0L wrx and didn't mention having a up pipe I would install one, consider it a preventative mod.
  14. #27
    MTM
    MTM is offline
    Registered User MTM's Avatar
    Feb 2014
    NorCal
    Black will dissipate heat better yeah, but I would use the special heat dissipation coatings before just painting it black.
    Also another guy and I will be doing his whole engine black in ceramic and heat dissipation coatings. My engine will be the control I guess. We will compare the heat dissipation coatings to mine which have none? Or at least are stock. (it has some type of gray coating but im assuming paint on the intercooler) So Ill have some of my own results too at some point. Not sure if we will be using that gray or black.
  15. #28
    zax
    zax is offline
    Nov 2008
    Facebook me here
  16. #29
    MTM
    MTM is offline
    Feb 2014
    NorCal
    **** YOUR SCIENCE YO!!
  17. #30
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by A265 View Post
    Yep.. uppipe and tires. Although I suppose it does depend on what wheels you have, and what tires you have on your current wheels.
