exhaust question
Results 1 to 6 of 6
This is a discussion on exhaust question within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Ok, so I recently had an invidia n1 catback installed on my 2014 wrx (hatcback) and am now looking for ...
    May 2014
    exhaust question
    Ok, so I recently had an invidia n1 catback installed on my 2014 wrx (hatcback) and am now looking for a catless uppipe and catted downpipe. I will likely go with the full Invidia system, but Im wondering if anyone has experience with the TurboXS or GrimmSpeed downpipes. How is the build quality and reliability on the TurboXS compared to Invidia? What are peoples opinions on spending the extra money and going with the ceramic coated Grimmspeed downpipe?
    Jan 2012
    New Jersey
    I havent heard of any problems with either brand. Why are you looking for a new up pipe? I believe after 05 or 06 they went with catless up pipes.
    CFLip2x 2012 WRB WRX Build
    Registered User 100plus2Vegas's Avatar
    Mar 2014
    Oceanside,Ca
    The 14 up pipe is catless. I like the up pipes by Cobb,Invidia and Perrin.
    14 sedan: Protune: 318AWHP 344ft lbs up pipe, Tial EWG, AEM intake, Cobb AP V3, 3" TBE, Avo FMIC, Turbo Smart bpv, Aem air fuel gauge,Cobb knob,Perrin Pitch Stop mount, SPT front strut tower brace, K-Sport coilovers@1.5" drop. Eibach sways, Perrin Spherical end links, Cusco subframe brace, White Line sway braces, Perrin sub frame bushings.
    07 Duramax LBZ- 26psi,intake, TBE, Diablosport programmer, Edge Insight with EGT, EGR block off, BD exhaust manifold, PPE fuel valve.
    Feb 2013
    Columbia SC
    if your gonna replace the up-pipe, you might as well get an EWG to go with it IMO. you wont get much out of an up-pipe with us late model guys....... if your looking to gain with an exhaust part besides the down pipe, i would suggest equal length headers. now theres a good gain right there.
    2013 WRX sedan - MODS = pretty much every bolt on besides a bigger turbo.
    STinfection WRX-maniac's Avatar
    Sep 2013
    Western Maryland
    Yup, what they said. Adding an aftermarket catless uppipe to your car will do nothing performance wise. Save up your money and do a uppipe for a external wastegate. Just know that you will also need injectors, fuel pump, wastegate, ebcs, pro-tune, and might as well throw in an aftermarket manifold too if you go that route.
    Stink-Eye Mob #301
    2012 WRB STi Limited Sedan
    2011 WRB WRX hatchback---Retired and traded.
    http://www.clubwrx.net/forums/builds...sti-build.html <---- My STi build thread
    http://www.clubwrx.net/forums/builds...ld-thread.html <----My WRX build thread
    Registered User 386WRX's Avatar
    Jan 2014
    Port Orange Florida
    If you throw in the manifold and injectors, might as well do a tgv delete and air pump delete while youre in there.
    I.e. just get a DP and youll be just fine OP
    Oh and how do you like the N1? Is it the dual street?
    Sent from my LG-E980 using Tapatalk
