Fuel pump would I max injectors?
Results 1 to 3 of 3
This is a discussion on Fuel pump would I max injectors? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I have a walbro 255lph pump I was wondering if it'd max out the stock injectors on my 02 wrx. ...
    Registered User frenziedcage's Avatar
    May 2012
    Colorado
    I have a walbro 255lph pump I was wondering if it'd max out the stock injectors on my 02 wrx. I've gathered parts for a turbo swap but I need a emergency tune cuz my car is running to rich and is bogging down and stuttering and jerking due to the tune I have on it if even threw a code due to this problem.
    Moderator Donkey's Avatar
    Da boonies,Va
    The fuel pump has absolutely nothing to do with IDC's.
    2002 FORESTER S
    1998 FORESTER S
    May 2010
    Pittsburgh, PA
    +1. You should do some reading on fuel systems.
    The injectors don't care how much flow is going past them. As long as there is fuel there, and it's the right pressure, they'll inject the fuel as expected, for the most part.
    ... If anything, you'd overload your fuel pressure regulator... Which you won't.
    Is there any reason why you are swapping the fuel pump right now? It most likely won't make a difference in your tune, especially with stock injectors.
    2011 STi Build Log
