EGT Sensor???
Results 1 to 8 of 8
This is a discussion on EGT Sensor??? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I'm having an up pipe and downpipe installed on my 05 WRX in prep for a tune this Monday. From ...
    Registered User JDMsoul's Avatar
    Mar 2012
    North Jersey
    EGT Sensor???
    I'm having an up pipe and downpipe installed on my 05 WRX in prep for a tune this Monday. From what I understand, I should leave the egt sensor off and not install it in the new up pipe. Let me know if that's correct? I want to make sure it's okay to tune it without it and my only concern will be a CEL afterward which can be disabled.
    Chris
    238 whp on stock turbo - Stage 2
    05 l WRB l WRX
    Registered User Obeisance's Avatar
    Apr 2012
    not Ann Arbor
    That's right. The sensor is needed to monitor catalytic converter health. With the tune, you won't even need to place a 2.2 kOhm resistor in the EGT sensor wire socket near the passenger strut tower (the mechanical CEL fix).
    David - '05 WRX
    Mar 2012
    North Jersey
    yep, i was worried for nothing.. its my first turbo car and its all new to me. new up pipe installed and plugged with no problem but now after the tune, I have a P0546 code.... lol it never ends
    Chris
    05 l WRB l WRX
  5. #4
    Mar 2012
    North Jersey
    The CEL came back on and it was the same EGT sensor P0546... got the resistor and placed it in, but it kept bending.. i got in as much as i could and put it as flush as possible on the sensor.... im hoping it doesnt fall off... it "seemed" stable... anyway, after turning on and off about 3 times, the CEL came right off... lets see if it stays on...
    worst case scenario, it falls off, can i cut the wire on the resistor to fit well without bending???
    Chris
    05 l WRB l WRX
  6. #5
            MainFrame's Avatar
    Austin, TX
    If you need a resistor to defeat the EGT sensor code, your tuner didn't tune the car right.
  7. #6
    Mar 2012
    North Jersey
    hmmm.. even before the tune, i was told, i would most likely need to do something for a CEL.... the car is running great and it put out more power than they expected on a stock turbo... i don't think i had a bad job done, but this is my first turbo car and my first tune...
    Chris
    05 l WRB l WRX
  8. #7
            MainFrame's Avatar
    Austin, TX
    Turning off the code in the tune is extremely simple and straight forward.. it's quite literally as easy as checking a box. If something so simple as that was overlooked, I would be worried about what else was overlooked in the tune.
  9. #8
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    As much as I hate to say this, I agree.....
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
