Pro tune
Results 1 to 5 of 5
This is a discussion on Pro tune within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Hey guys I'm going in for a pro tune for my 05 wrx with a catless uppipe and down pipe ...
    Feb 2014
    Question Pro tune
    Hey guys I'm going in for a pro tune for my 05 wrx with a catless uppipe and down pipe and the tuner said I need a bigger flue pump for the tune. If I don't need a bigger fuel pump for cobb stage 2 then why do I need one now?
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Who is the tuner? Your fuel pump is adequate for the 420cc injectors.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Registered User Obeisance's Avatar
    Apr 2012
    not Ann Arbor
    - I'll translate that for you. As long as your chimney is stock, you don't need an upgraded pump- the flow potential is fine as is. On the otherhand, if you have some flue blockage, a good chimney sweeping may help prevent fires.
    David - '05 WRX
    Feb 2014
    I'm getting tuned at equalibirum by Ed in Fairfield CA .see that's why I'm confused because I'm stage 2 right now with a cobb map and I don't need a new fuel pump so why will I need one now? Will it provide more power?
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by 05'Franco View Post
    No. I think that is a silly requirement. The only thing a larger fuel pump will do with your stock injectors is heat the fuel.
    Fuel pumps should be matched with injectors, unless you plan on running higher fuel pressure which will require different fuel rails and an adjustable fpr.
    Facebook me here
