Injector question
Results 1 to 15 of 18
This is a discussion on Injector question within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I'm doing some major mods on my 2010 wrx some smog legal some not. I know when it comes time ...
    Mar 2012
    Sacramento
    Injector question
    I'm doing some major mods on my 2010 wrx some smog legal some not. I know when it comes time I will have to pull it off to pass smog but my question is I'm going to 1300cc injectors can you pass smog with a larger injector ? I live in Ca and the smog laws are on the strict side. Should I keep my stock ones for when it comes that time ?
            MainFrame's Avatar
    Austin, TX
    Injectors should have no effect on smog as long as the car is tuned properly.
    I hope they're not Deatchwerks 1300s..
    Mar 2012
    Sacramento
    I was looking at fiveo injectors
  5. #4
            MainFrame's Avatar
    Austin, TX
    Five-O injectors are hit or miss.. when they do work they're not that great. They're used injectors that they modify to increase the flow. I would recommend going with a new injector, like what Injector Dynamics sells.
  6. #5
    Mar 2012
    Sacramento
    Thank you I will check them out. Side feed or top ? Is it really that big of difference ?
  7. #6
            MainFrame's Avatar
    Austin, TX
    There's not much difference.. just that 04-06 STi came with side feed, basically everything else came with top feed. If you have a 2010 side feed injectors won't fit on your car.
    If I may ask, what turbo and fuel do you plan on using that you need 1300cc injectors?
  8. #7
    Mar 2012
    Sacramento
    Stock turbo but I'm going to e85 and my tuner said that was a good size to switch to. I was thinking about doing a turbo swap but then that's a motor build, tranny, rear end and about a hundred other things so since e85 is everywhere where I live I would try it out. It was a toss up with water meth injection but I choose e85
  9. #8
    As long as you don't have a CEL, don't have visible modifications that scream "I'm illegal!" and the tested doesn't know what to look for you will be OK -- provided of course that your car meets the actual emission maxima. If you're polluting or obvious you'll have issues.
    Les jeux sont faits.
  10. #9
            MainFrame's Avatar
    Austin, TX
    I would definitely not run 1300s on a stock turbo.. That makes me question your tuner's competence. Just get ID1000s for e85 on a stock turbo.
  11. #10
    Mar 2012
    Sacramento
    He originally told me 1000cc but with my fmic he said that's adding a lot of air for the turbo and if I want e85 with it I'm going to have to use a bigger injector. In his defense he said he really needs to get my car on the dyno but with a fmic it's hard to tell if 1000 will be enough
  12. #11
            MainFrame's Avatar
    Austin, TX
    750s would probably be enough on stock turbo.. FMIC doesn't make your turbo move any more air than a good TMIC, you can run maybe 2-3psi more but psi doesn't equal flow. Anything over 1000cc will sacrifice smoothness and idle. ID1300s are designed specifically for e85 use, but they're not cheap.. especially when the car should run better on 1000s anyways.
    I know people that have made over 500whp on ID1000s with e85.. on the stock turbo you're only looking at around 330-340whp.
  13. #12
    Mar 2012
    Pasadena, MD
    I agree with MainFrame, you definitely don't need more than 1000s for E85 with the stock turbo...and I highly recommend ID as well, I have them in my car along with a Walbro 255 and the car idles better than stock and runs great. I'm also just about to get tuned on E85 on 11 June so I can let you know how that goes and what my IDC is if you're concerned and can wait until then...just check out my build thread, that's where I'll post up my dyno numbers. Hope this helps!
  14. #13
    Mar 2012
    Sacramento
    I will get the 1000cc injectors then. 360 whp is what everyone is saying is max out of stock turbo and stock internals so I would think with everything else that's done to the car I will be at its limit
  15. #14
    Mar 2012
    Sacramento
    Yea I will check out your build thread for sure. I'm not in that big of a hurry I have some major mods I'm doing next month
  16. #15
    Mar 2012
    Pasadena, MD
    I'm pretty close to the limits as well, the only things I haven't done are TGV deletes/phenolic spacers, turbo inlet, port and polish the stock turbo and a few other small things...but it's nothing that would gain me any significant power to justify the pain in the rear and cost it is to do those mods. Thus why I'm holding off until I either swap out the turbo or go rotated at some point but that's WAYYYY down the road, the car is my DD so I'm going to make myself be content with whatever I get out of the car on E85...
