What mods needed to run a 20g turbo on a 2.0
Results 1 to 15 of 17
This is a discussion on What mods needed to run a 20g turbo on a 2.0 within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Hi everyone, I have a 02 bugeye and I'm wanting to upgrade my turbo, I have a new TD05 20G ...
    Registered User rgcwrx's Avatar
    May 2014
    Delta jct. Alaska
    Hi everyone, I have a 02 bugeye and I'm wanting to upgrade my turbo, I have a new TD05 20G turbo laying around that I wanted to use, so I was wondering what supporting mods I would need in order to run that turbo?
    Registered User Impreza2.0's Avatar
    Nov 2008
    Maine
    larger injectors, pump, intercooler, couplings, up pipe, turboback exhaust, and a tune. That is a large turbo... it will need air. the intercooler you want is pretty big. i'd contact the turbo's manufacturer and ask what size core you should use. You might find out it's a front mount intercooler or nothing... not sure with that snail.
    otherwise ^those are the standard upgrades for most turbo swaps. You can't really go to big without doing those things.
    be sure to find a tuner if you are not sure how to do it yourself.
    again, that's a big turbo, and it could hurt itself or your motor, or you... to drive it without supporting software changes.
    May 2014
    Delta jct. Alaska
    Well so far I have a up pipe and turbo back exhaust, and I have a Cobb AP. What ETune service would you recommend to get the AP tuned? Can I use 91 octane fuel with this turbo or will I have to go 93?
  5. #4
    Nov 2008
    Maine
    I'd start by contacting Cobb. Tell them exactly what parts you have, and ask what can be done.
    You can still use 91o... though you may get better results w/93, I'd ask them that, too.
  6. #5
    STinfection WRX-maniac's Avatar
    Sep 2013
    Western Maryland
    You would be better off with 93 octane. But 91 will work. Thats a pretty large turbo my friend, find a very reputable tuner, call them and ask for their advise on the build and follow it. Honestly, there is absolutely no need to contact COBB. Sure they might give you some friendly advise on what to do as far as your build goes, but it may be different than what your actual tuner recommends. Period. Impreza2.0 was pretty much right on dot on the modifications needed to run this turbo, but when it all comes down to it, the tune will make or break your car. That large of a turbo on a 12 year old car with presumed stock engine and internals. Also, the accessport thing only matters on what your tuner prefers. Some tuners require you to have the accessport to tune, others use the opensource method. Again, ask your tuner.
    But, before you start to anything to your car, you need to be sure it is healthy. 12 years old and who knows how many miles? Completly service your car, do your timing belt if it has not been done, change all fluids, then do a leak down/compression test. Make sure that your engine can handle these upgrades before you proceed.
    Stink-Eye Mob #301
    2012 WRB STi Limited Sedan
    2011 WRB WRX hatchback---Retired and traded.
    http://www.clubwrx.net/forums/builds...sti-build.html <---- My STi build thread
    http://www.clubwrx.net/forums/builds...ld-thread.html <----My WRX build thread
  7. #6
    May 2014
    Delta jct. Alaska
    Well the main reason I want to go with that turbo is because I already have it. But yeah I'm doing the timing belt and tune up when I get in to changing the turbo. And as far as mounting the turbo on the car do I need some special mounts since the turbo is quite a lot bigger than the stock turbo?
  8. #7
    Where do you live? E-tuning should only be done on that setup if you're a long distance from someone reputable
    2005 WRX STi (Mods | Virtual Dyno) - Weekend Warrior
    Resident Tuner @ WTF Tuning
  9. #8
    May 2014
    Delta jct. Alaska
    I live in delta junction Alaska in the middle of nowhere and the nearest tune shop is a 6 hour drive.
  10. #9
            MainFrame's Avatar
    Austin, TX
    Phatron, WTF Tuning, and Keith @ AWDTuning all offer e-tuning services, and are decent tuners that won't blow your engine up. E-tuning isn't ideal for any car with a turbo swap, but if that's your only option so be it.
    The higher octane fuel you can run the better..
    If the 20g that you have is designed for OEM Subaru fitment, then you should be able to bolt it right up.. basically. You never said which 20g it is though, so it's hard to say.
  11. #10
    May 2014
    Delta jct. Alaska
    Oh ok thanks for all the info guys! But about the turbo all I know is it's a TD05 20g turbo I'm not sure on the brand.
  12. #11
            MainFrame's Avatar
    Austin, TX
    If it's an eBay special (cheap Chinese knock off), then I wouldn't even bother installing it.. they're junk.
  13. #12
    May 2014
    Delta jct. Alaska
    What kind of turbo would you recommend that's not too expensive but still decent quality?
  14. #13
            MainFrame's Avatar
    Austin, TX
  15. #14
    May 2014
    Delta jct. Alaska
    Oh ok. How good are Godspeed turbo's?
  16. #15
    Aug 2012
    Tucson, AZ
    Quote Originally Posted by rgcwrx View Post
    Ebay. Wouldn't trust it in my opinion
    Sent from my SCH-I545 using Tapatalk
    Stinkeye member 520
