stage1 not working... PLEASE HELP - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 37 of 37
This is a discussion on stage1 not working... PLEASE HELP within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; yes im.in colorado springs at the moment I did a 3rd gear pull today...at 4500 rpm I hit 14 psi ...
  1. #31
    Apr 2012
    colorado springs/williston, nd
    I did a 3rd gear pull today...at 4500 rpm I hit 14 psi then no more boost...
    regardless of elevation..... should I be hitting peak boost so early.
    if so...thats fine. what can I do to get my boost to peak at closer to 19?
  3. #32
    Aug 2012
    Tucson, AZ
    Quote Originally Posted by schnaidt1 View Post
    You'll hit peak boost then watch it fade away as your wastegate opens
    Sent from my SCH-I545 using Tapatalk
    Stinkeye member 520
  4. #33
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    It doesn't work that way. Like I said, the target boost is set to a variety of factors to optimize volumetric efficiency. 19 PSI at 5000 feet with your mods and the turbo would be heating the air more than providing additional flow. The car is hitting target boost for your altitude. Nothing you need to do!
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  6. #34
    Jul 2011
    Hunterdon County
    Quote Originally Posted by nsibanez View Post
    Just be happy you hold 14 psi to redline and aren't touching the top end of the turboes performance.
    It is real fun to watch your boost gauge at 21 psi up until about 5K and just watch it plummit after that because you're turbo can't keep up. I don't have this problem on my HellaStock WRX, but my old 14B powered DSM. That snail was only good up until around 5,000 rpm, then it tapered off real quick.
  7. #35
    Palmyra, NJ
    So you're turbo and boost are acting normal for your elevation. You can go stage 2...and get a protune. You'll still only end up seeing 16ish at a Stage 2 OTS level, so a protune is pretty much the only way you'd get what you want.
  8. #36
    Apr 2012
    okay thanks for ur input. I don't know much and thought it was weird I hit max boost at 4500 rpm then lose it an power.
    from what ur saying I need to wait until I can go stage 2 and get a protune.
    question. . would running the hwg map help at all? ?
  9. #37
    Registered User Spyder65's Avatar
    Apr 2014
    Long Islands South Shore
    Dealer question
    i want to thank everyone who replied....you all were right...i took it into subaru and they discovered a few things. they fixed it and its back to normal. however...now i got a new question..
    i reinstalled my stage 1 91+sf from cobb...my car feels good.,.....however it will not go past 14lbs psi....it should go higher....and here is the kicker...it hits that 14lbs at 5k rpm....with 2k rpm left it doesnt give anymore boost....just stays there...
    can anyone give any food for thought on why my boost is stopping short and how i can get my psi to hit up in the 17 range like its supposed too? thank you
    Just curious. What were some of the issues the dealer found?
