stage1 not working... PLEASE HELP - Page 2
Results 16 to 30 of 37
This is a discussion on stage1 not working... PLEASE HELP within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Make sure to look at the intercooler connection points....
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Apr 2012
    colorado springs/williston, nd
    well. .. checked all connections top side. ... everything was good. ...so... any other suggestions for my next move? ??
    6lbs psi is horrible lol. my car creeps in acceleration
    Nov 2012
    Smoke test it.
  6. #19
    Village Idiot McBill's Avatar
    Sep 2013
    Buckeye State
    Smoke test it.
    this
    Billy
    2009 Ducati Monster 1100
    2008 Legacy 3.0R - SOLD
    2011 WRB WRX Sedan - SOLD
    Stink-Eye Mob #696
    Facebook
  7. #20
    Apr 2012
    how do I do that??
  8. #21
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Quote Originally Posted by schnaidt1 View Post
    If your car is not making boost at all, I'd not mash the accelerator any more. The next step would be to take it to the shop and have the shop run a vac/boost leak test (with smoke is the best method). You can do this yourself, but it sounds like you might be a bit in over your head. Also, I would take a look at your fuel trims to see if you have a gross leak during CL fueling.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  9. #22
    Jul 2011
    Hunterdon County
    [QUOTE=zax;3501753]I'd suspect a boost leak.QUOTE]
    +1.
    I'd say that something was not put back together 100% correctly on the intake tract, even if it is just a boost leak somewhere or the MAF is slightly out of position. The OTS map would be one of the last things I blame in this situation.
  10. #23
    Apr 2012
    I do get some boost just not much. ....I have to really step on it. .. my car will crawl til 4k rpm an then a lil boost will kick in. .. most times under 5lbs psi...
    anything under 4k an it kicks in so little that it barely brings the gauge up above the vacuum....
    it used to be so responsive an quick an give good boost. ... I'll check all those ideas guys thank you
  11. #24
    Jan 2014
    East Coast
    Is your boost guage and cobb showing the same peak boost? It sounds like a boost leak or your wastegate is staying open. Only odd thing is that normally a boost leak will cause the car to stumble a bit.
    Chris
    '14 WRX Crystal Black/SPT CBE/Tuned by Torqued Performance
  12. #25
    zax
    zax is offline
    Nov 2008
    Quote Originally Posted by chris410 View Post
    If the leak is significant, the flow will be very consistent and CL fueling will be able to pull in the trims.
    Facebook me here
  13. #26
    Dec 2012
    Northern, Virginia
    to the OP... you said you were monitoring boost in 1st and 2nd gear. Try a 3rd gear pull, full boost should happen 3000-3600 rpm. In 1st gear there wont be enough load on the engine to get highest boost.
  14. #27
    Apr 2012
    i want to thank everyone who replied....you all were right...i took it into subaru and they discovered a few things. they fixed it and its back to normal. however...now i got a new question..
    i reinstalled my stage 1 91+sf from cobb...my car feels good.,.....however it will not go past 14lbs psi....it should go higher....and here is the kicker...it hits that 14lbs at 5k rpm....with 2k rpm left it doesnt give anymore boost....just stays there...
    can anyone give any food for thought on why my boost is stopping short and how i can get my psi to hit up in the 17 range like its supposed too? thank you
  15. #28
    Aug 2013
    Southwest Oklahoma
    What gear are you in when hitting 14? If you havent tried already, try doing the pull in 3rd gear as this is where you will hit your peak boost. Sorry if this has already been mentioned.
  16. #29
    Palmyra, NJ
    Are you in Colorado right now when trying this? You're much higher above sea level there so boost won't be as high.
  17. #30
    zax
    zax is offline
    Nov 2008
    Yep. Mikie nailed it.
    The turbocharger has a specific efficiency range to which the map is calibrated. For example, 17 PSI is 2.15:1 Pressure Ratio at sea level (compressor outlet: compressor inlet). The 17 PSI is actually measured at the MAP sensor, so this does not really represent the pressure ratio, but you understand my point for illustration.
    Now, in Denver, CO (for example), the elevation is roughly 1 mile -- 5280 feet. At this altitude, the atmospheric pressure would be [typically] around 12.1 PSI compared to 14.7 PSI at sea level. Therefore, at the same PR of 2.15:1 your target boost is 13.92 PSI corrected for altitude. Is this what you're seeing?
    Facebook me here
