TMIC or FMIC
Results 1 to 9 of 9
This is a discussion on TMIC or FMIC within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; We'll guys what do you think? A better TMIC or go with a FMIC?...
    Feb 2014
    TMIC or FMIC
    Oct 2013
    Well, there's not much to say if you don't give us your setup or your objectives...
    Sent from my Nexus 4
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    A high quality TMIC (bar and plate) upgrade will serve you very well. These will outperform a mediocre FMIC. As long as you have a stock location turbo, I would (and did) go with a high quality TMIC (ProcessWest, and ETS make excellent ones). If you are going with a rotated turbo set up, then a high quality FMIC would be the way to go. Here are some links with a little info on each. Either way, you would want to get the car properly tuned to take advantage of the benefits whatever intercooler you end up going with.
    FMIC FAQ: Read if you are thinking of buying one! - NASIOC
    TMIC FAQ: Read if you are thinking of buying one! - NASIOC
    Jan 2012
    New Jersey
    Since you have an 05 you will have more choices for TMIC. If you dont need a new one then I would say spend the money on other upgrades.
    CFLip2x 2012 WRB WRX Build
    Palmyra, NJ
    Unless you're running a large or rotated turbo setup...stick with TMIC.
    Feb 2014
    I'm running a TBE all catless and catless up pipe. I just want to pull as much as I can out of my stage 2 while I slowly collect Everything for a vf39 upgrade. Lol
    May 2007
    orlando flawduh
    +1 to the above. Skip the FMIC. Even with a vf39, it won't benefit you
    desiree
    Palmyra, NJ
    Quote Originally Posted by 05'Franco View Post
    With either one, you won't benefit fully without a retune anyway...
    ClubWRX.net Vendor WTF Tuning's Avatar
    Feb 2014
    A small turbo warrants the powerband and response as soon as possible, which means you should be looking at a TMIC. As mentioned, PW or ETS are what you should be considering.
