STAGE 2? ? ? COBB AP
Results 1 to 15 of 15
This is a discussion on STAGE 2? ? ? COBB AP within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Thinking about buying a COBB AP and going Stage 2 with Downpipe and intake. what are your thoughts?? Owner of ...
    Nov 2013
    Honolulu, Hawaii, United States
    Owner of a 2014 Black Wrx Hatchback 6.5k Miles.
    Wanting better sound and power, and a stronger running engine!
            MainFrame's Avatar
    Austin, TX
    Should be fine as long as you follow the map notes.. but you should datalog every once in a while to make sure your car is happy with the map.
    STinfection WRX-maniac's Avatar
    Sep 2013
    Western Maryland
    +1
    Also, whenever you are deciding to buy your parts to go stage 2, the only real specific thing you need to buy is the intake. Meaning, that you DO NOT have to buy Cobb's turbo back exhaust to run their stage 2 map. The only thing that matters in the exhaust is that the downpipe MUST have a cat. So you can run an invidia, nameless, turboxs, etc turbo back exhaust as long as the downpipe has has the high-flow cat. Cobb only supports their SF or the AEM cold air intake with their OTS maps. Doesnt mean that you absolutely have to use one of those 2 intakes though. Some companies, such as perrin, will supply you with their stage 2 map for the intake when you purchase an intake from them.
    But good luck, stage 2 is an amazing step in power, and alot of fun!
    Stink-Eye Mob #301
    2012 WRB STi Limited Sedan
    2011 WRB WRX hatchback---Retired and traded.
    http://www.clubwrx.net/forums/builds...sti-build.html <---- My STi build thread
    http://www.clubwrx.net/forums/builds...ld-thread.html <----My WRX build thread
    Dec 2013
    I did that set up with my 2014 and I am happy. I did the cobb ap, sf, and DP, with the dual invidia n1 and I couldn't be happier with the power and sound
    Jul 2012
    Rocky Top
    ^This
    Quote Originally Posted by WRX-maniac View Post
    Also, whenever you are deciding to buy your parts to go stage 2, you DO NOT have to buy Cobb's turbo back exhaust to run their stage 2 map. The only thing that matters in the exhaust is that the downpipe MUST have a cat. So you can run an invidia, nameless, turboxs, etc turbo back exhaust as long as the downpipe has has the high-flow cat. Cobb only supports their SF or the AEM cold air intake with their OTS maps. Doesnt mean that you absolutely have to use one of those 2 intakes though. Some companies, such as perrin, will supply you with their stage 2 map for the intake when you purchase an intake from them.
    ^and this
    Stage 2 is about the biggest bang for your buck as far as power mods. And it's simple. There are other options besides the Cobb AP. I personally don't like the OTS maps from Cobb, there is much left to be desired. All you really need to make the stage 2 power is a downpipe and a tune. But I imagine, like many of us, you will want a few more mods with that
    Nov 2013
    id suggest getting a protune
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by 13WrXx View Post
    Not a bad idea..
    Nov 2013
    Yea I think a $500 investment is a good idea when it comes to modding and a peice of mind.
    Nov 2013
    Much appreciation guys to the advice, i'll be getting my COBB ap in soon! Is installation easy?
    Nov 2013
    Also i've been hearing things about the invidia catless and catted downpipe, what are the differences? Besides the fact it doesnt have a catalytic converter... (DUH). Also, running catless is illegall in Hawaii!
    Jul 2012
    Rocky Top
    Yes, installation is easy. Just read the manual that comes with the AP and it should be very clear.
    That is the only difference b/t catted and catless. Invidia also offers different styles like divorced and bellmouth.
    Nov 2013
    If your planning on running the ots maps get a catted downpipe. The cobb maps are meant for catted downpipes,
    Registered User mugentheman215's Avatar
    Apr 2013
    Mifflinburg, PA
    With the catless DP there is a higher tendency to see boost creep issues, that sometimes can be tuned out but for the most part can only be solved with and EWG setup. Just some food for thought, i personally went with the catted DP.
    2013 WRX Sedan WRB | Gentleman's Alliance
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by Dwata808 View Post
    Cobb's map notes for stage two clearly state that a CATTED downpipe is required.
    iH4
    iH4 is offline
    Registered User iH4's Avatar
    Apr 2013
    the OC
    I'm running that exact setup, all from Cobb catted downpipe, intake, (not pro-tuned, yet) but very, very pleased with performance - night and day from stock. I went to Stage 1 at 1k miles, then Stage 2 at 3k miles... in less than a year, I have already racked 19,000 with no issues... bought the car back in June 2013.
    Time for AWD fun! CBS 2013 WRX Sedan - SoCal - OC
