Swapping parts from 2012 into 2002 WRX? Possible?
Results 1 to 9 of 9
This is a discussion on Swapping parts from 2012 into 2002 WRX? Possible? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; So I searched and searched and couldn't find anything on this. So I'm starting a thread. So I have a ...
    Mar 2012
    So I have a 2002 WRX.
    I have a company that I work with that has a smashed up 2012 WRX with the powertrain in good shape.
    Do you guys know if that 4th gen setup is a direct swap into the 2ng gen?
    Basically, I have these questions. Will the:
    Engine and tranny swap over?
    Suspension bits swap over?
    Any info you guys have would be greatly appreciated
    Thanks!!!!
    Jul 2012
    Rocky Top
    Considering it's a completely different chassis I would say, no. Struts/springs won't fit, sway bars won't fit. It's also very likely your wiring harness won't match up to the new motor either. A lot has changed since '02.
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Transmission: Likely yes.
    Engine: Sure, but you'll have to deal with the ECU and harness swap. Alternatively, you could plug the AVCS on the heads and run the longblock while swapping over the intake manifold.
    The bigger question: why go through all the trouble?
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Mar 2012
    The car now is misfiring on cylinder 3 and has 160K on it. I would be getting such a fantastic deal on the new set up I'd be dumb not to find a way to make it work.
    I did start researching the Hybrid option. I'm not looking for a racer, just a nice quick daily driver. So maybe I could just swap the blocks, trans and turbo and keep everything else from the 02'?
            MainFrame's Avatar
    Austin, TX
    You could swap the engine/turbo/transmission/wiring/ECU.. you would need to splice the harness and find a way to make it work with the rest of the car, but I'm sure it can be done.. just take a lot of electrical work.
    Mar 2012
    Thanks. I'll start researching it, I would think there has to be a company that sells already spiced harnesses.
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    Quote Originally Posted by dsilby View Post
    Already spliced? I seriously doubt that. There isn't enough of a market for harness shops to spend money and $$$ researching it. You may find a company to do it for you, but it will be a 100% custom job, and will definitely be $$$.
    2007 Outback 3.0R wagon
    Mar 2012
    Quote Originally Posted by Rambo View Post
    I'll have to look into it further. I swear I came across company that does that for $250 (or something like that).
            MainFrame's Avatar
    Austin, TX
    I've seen places that will do bugeye to GC harness merges in the past, but they were all over $1000.
