Disconnected my battery on my 2006 sti, now its doing something it normally doesnt
Results 1 to 7 of 7
This is a discussion on Disconnected my battery on my 2006 sti, now its doing something it normally doesnt within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; So today I tried to install my hella horns that i bought at boxerfest yesterday and got incredibly overwhelmed and ...
    Registered User ravesilly's Avatar
    Apr 2014
    Bel Air, Maryland
    So today I tried to install my hella horns that i bought at boxerfest yesterday and got incredibly overwhelmed and gave up. Now while trying to install the horns I was told it would be smart to disconnect both leads on the battery (which I did). So after I got everything hooked back up I went to start it up to pull it back into the garage and when I normally start it up cold, it goes up to 1500 rpm then starts to climb to 2000 rpm and then a slight throttle push drops the rev to about 500 and then it goes right back up to 1500 and stays there. This time it started up went to 1500 rpm and stayed there, didnt climb our do anything else. Now when I went to gingerly tap the throttle it dropped to about 400 give or take (that didnt really bother me as much as it should have) and climbed to 1500 again. Now this is the part that is scaring me. When I let warm up for about 8 min and it was at a decent rpm of about 800-900 rpm I gave it a quick rev to 2000 because well.... i wanted to hear the rumble, and it dropped to i kid you not, 100 rpm (maybe even lower) almost stalled and did its normal rpm climb speed. It did this 3 times before i got scared and quickly pulled it into the garage and shut it off. Now I did check my maps on the cobb accessport and it says it still has the stage 2 93 v300 map on it so I dont know if its saying that because it is saved on the accessport both reflash and the other one (forgot the name)or it genuinely is still on the car. Im scared to drive it becauase im afraid It will stall and I really dont want to touch anything on the accessport unless I really have to. Im bringing it to my tuner on tuesday for a brake squeal and a swaybar install on tuesday and I just want to know if this is normal after disconnecting and reconnecting the battery or I should genuinely be worried.
    TL DR: I disconnected and reconnected my battery while attempting to install hella horns and the car almost stalls (drops to 100) when i rev it and it idles lower than normal when i start it. Accessport says maps are still installed but im not sure if i should believe it or not.
    Any help would be appreciated guys! Im really scared that I might have messed something up
    You cannot measure 100 rpm. Make sure the leads are secure and drive the car as normal.
    Apr 2014
    Bel Air, Maryland
    will the car eventually go back to like it was before?
    Registered User BlankWRX's Avatar
    May 2013
    Queens, NY
    Make sure you tighten the leads on the battery.
    '13 WRX WRB Sedan
    Rain, sleet, snow... drive it.
    STinfection WRX-maniac's Avatar
    Sep 2013
    Western Maryland
    Usually when you disconnect the battery it takes the ecu a little bit to re-learn the map and stuff. This has been the case with both of the wrx's that I went Stage 2 with.. After flashing the new map is ran very similar to what yours is doing for about an hour or so, then it smoothed out.
    Stink-Eye Mob #301
    2012 WRB STi Limited Sedan
    2011 WRB WRX hatchback---Retired and traded.
    http://www.clubwrx.net/forums/builds...sti-build.html <---- My STi build thread
    http://www.clubwrx.net/forums/builds...ld-thread.html <----My WRX build thread
    Palmyra, NJ
    Disconnecting the battery won't just remove a map off the car. So you're fine there.
    And as SD said...look closely at the gauge cluster: the bottom line of the tach isn't technically at 100rpm. Idling from a cold start around 1500 is normal. And after disconnecting the battery for some period of time like you did, your ECU just reset the learning parameters (different than the map), so you're likely just feeling that. Go drive the car around so it can begin to relearn fueling and you'll be fine.
    Or I'm completely wrong and your car is gonna blow up. Take your pic
    Jul 2012
    Rocky Top
    Yeah, it's gonna blow up. Had the same problem not too long ago.
