Boosting a stock WRX?
Results 1 to 15 of 20
This is a discussion on Boosting a stock WRX? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; So I tried to find a thread dealing with some of my questions but didn't see anything.... So here we ...
    Registered User BOshea's Avatar
    Mar 2014
    Houston Tx
    So I tried to find a thread dealing with some of my questions but didn't see anything.... So here we go.
    Now after reading up on some of Specs on the factory parts in regards to boost PSI on the OEM parts can handle. For example: the OEM Wastegate can handle around 20PSI.. What would happen if i tuned the car while increasing the factory setting 14.? Psi to 20PSI? Would there be significant performance noticed? I would assume so. But Can all the other components handle the added pressure? I just figured this is an interesting thought..
    Ultimately my goal is purchase a bunch of parts : CAI, AOS, Full exhaust, Larger TMIC, BOV, MCIS Suspensions, Braking system upgrade, Short Throw, etc. And then bring all my parts (specifically motor parts) have them installed at one time and tuned at one time.
    Would this be the most beneficially or cost efficient? Is there a better suggestion?
    Obviously MY car has 3K on it so this is just planning for the future when my warranty is done.
    I know this is a bunch of question but i do appreciate the time anyone takes to look into this...
    Jan 2012
    New Jersey
    my 12's max boost has been set to 19pis and so far the only "problem" is the Throttle body hose tends to get loose every few months or so and I just have to readjust it. Who would be tuning your car or will you be using an accessport? The rest of the mapping has also been adjusted not just the max psi. Get an accessport and downpipe flash the ecu. AOS can wait not necessary just yet.
    CFLip2x 2012 WRB WRX Build
    Mar 2014
    Houston Tx
    Well i'm in Texas and i heard about a place called EngineLogic... So i'm probably just going to go there to have them do any of the work i need done in terms of Motor specific..
    Good to know that you're running 19PSi without any serious issues
    Jan 2012
    New Jersey
    Talk to them first see what they will require they can give you better answers
    Mar 2014
    Houston Tx
    Alright.... SOunds like a plan. Once i start ordering my parts i'll find out
    Jan 2012
    New Jersey
    Talk to them before you order parts they can probably suggest an upgrade path.
    Registered User 386WRX's Avatar
    Jan 2014
    Port Orange Florida
    Ya im running 19 PSI on my TP stage 2 tune. Only problem I had was blowing a bolt off the BPV under full boost one time. Got it torqued down nice and tight now though!
    Not sure if you can just turn up the boost on a stock car like that though..
    According to my map notes, a DP, EBCS, and a larger TMIC is what is required to run 20 PSI. Bare bones ofc.
    At that point, might as well replace the BPV, cause it'll blow at some point.
    63k on my 2011, and she loves it
    Registered User ZXNasty's Avatar
    Nov 2013
    Murray, KY
    I also run 19 psi on my 14 WRX with a TP stage 2 tune. No problems so far.
    Sent from my SAMSUNG-SM-N900A using Tapatalk
    Mar 2014
    Houston Tx
    Quote Originally Posted by ZXNasty View Post
    What type of gains did you accrue from using more boost?
    Did you have a dyno done or do you have an estimate of new HP production?
    Nov 2013
    Murray, KY
    No idea. Never been on a dyno so no way to tell HP. Fast enough to be plenty to enjoy and mileage went up too
    Jan 2014
    Port Orange Florida
    Didn't ask me, but here you go, this is mine.
    That's on a dyno jet virtual dyno.
    Here is a comparison between 3 stages, including stock on a caution correction factor.
    Sent from my LG-E980 using Tapatalk
    Mar 2014
    Houston Tx
    Well that is quite the difference. Thank you for your input 386WRX Much appreciated.
    Thanks guys. I will have to see when I can get to the tune shop and what it'll cost me.
    ClubWRX.net Vendor WTF Tuning's Avatar
    Feb 2014
    There is more to making power in a Subaru than upping the boost...ignition advance, camshaft advance, and fuel are other factors
    Mar 2014
    Houston Tx
    Quote Originally Posted by WTF Tuning View Post
    Very True... I was just curious on what would happen if you pushed the limit of OEM. I want/will upgrade when i start to get bored with the performance and warranty of the car.
    I'm going to start with outside appearance (wheels, tires, suspension, etc.) And then Audio.. Radio Stinks!!
    Mar 2014
    Westchester, NY
    I actually had a similar question to this that I was searching for around the forum. Basically, I was wondering what type of boost the stock turbo can handle without issues. I plan on doing upgrades over time as well, and I was just wondering. I assume at each stage tuners or a Cobb OTS map pushes it close to what still works with other parts that have been installed, but I just wondered at what point the turbine can fail and whatnot. is it 22,25 30 psi?
    2014 Subaru WRX Limited Sedan in Crystal Black Silica
    Mods - STi Short Throw Shifter w/ Cobb Bushings,Totsubo Front License Plate Mount
    2015 Dodge Durango Citadel in Bright White
    Retired: 2002 Subaru Impreza 2.5 RS 5-speed, 2005 Acura RSX Type-S 6-speed, 2010 Honda Accord Couple EX-L V6 6-speed,2009 Acura RDX w/ Tech Package in Grigio Metallic.
