Pushing the HP limit while keeping the car reasonbly reliable
Results 1 to 15 of 19
This is a discussion on Pushing the HP limit while keeping the car reasonbly reliable within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Hey Guys, First post so please forgive me for any missteps I make. I recently purchased the following car with ...
    Registered User sky_night's Avatar
    Apr 2014
    Flagstaff, AZ
    Hey Guys,
    I recently purchased the following car with the mods listed:
    2012 WRX Sti (15,000 miles on it)
    Supersize Down-mounted ETS Intercooler Kit
    TOMEI Exhaust Headers
    SAMCO Sport Hoses
    Light Weight Crank Pulley
    H&R Adjustable Coil Over Kit
    SPI Exhaust System
    DC Power Engineering Alternator
    Cobb SF Intake System
    Perrin Strut Bar
    Crawford Performance Air Oil Catch Tank
    TurboXS Blow of Valve
    Injector Dynamics (injectors)
    Invidia High Performance Downpipe Exhaust
    Garrett Turbo with Polished Hosing (Part Number: PCM 65223 706451-5005S)
    Cobb 3 Port Boost Control Solenoid
    Stage 3 Clutch Kit (not sure manufacturer on this as of yet)
    Perrin Control Arm Bushings
    KOYO Aluminum Radiator
    If you want to see pictures of the engine/car go here Subaru Impreza WRX STI Limited | eBay
    Note that in the ebay posting it shows what the car looks like before the wreck and after. I have already performed all work to get the car looking just as it did when it's new (including stuff like alignment). I have also attached a picture to this thread of what the car looks like now.
    What I'm looking for is everyone's opinion on what parts are good/bad on this build. Additionally I'm looking to see if I can keep some good reliability after getting a built short block for the car. My local tuning shop says if I spend about $6,000-$7,000 on a short block build that I could push my car close to 600HP. I don't imagine at that HP I would get any long term reliability out of the car. So I'm trying to find out if I did spend the money to get a built short block what HP level could I obtain while still keeping some level of reliability from the car. Lastly any suggestions on other upgrades you think may help my build (the more specific the better).
    Thanks for any input you have.
    Registered User 386WRX's Avatar
    Jan 2014
    Port Orange Florida
    Tuned for 110 octane? Man this thing has been beat to hell and back. Not a bad price though, will be able to part it out for more than you bought it for when it goes boom.
    My vote is 400 awhp. More experienced people will give you more insight.
    I will tell you there are a few people on here with over 400 awhp, not sure if they are dailies, but yeah.
    Welcome! And good luck
    Sent from my LG-E980 using Tapatalk
    Jan 2012
    New Jersey
    Welcome Good luck with the car just a couple of corrections and additions.
    Its an AOS (Air Oil Separator) no need to empty it should drain back.
    SPT Exhaust,
    Equal Length Headers,
    Catless Downpipe
    Looks to also have whiteline sway bars, chassis bracing, control arm brace.The Uppipie also looks to be Tomi.
    Hella Horns
    Grimmspeed Lightweight Crank Pulley
    Do you know if it has a short throw shifter and bushings?
    Get a heat shield or turbo blanket. Also get a wide band and some extra gauges. If you can set the the Bypass Valve (Blow Off Valve) to recirculation instead of Vent to Atmosphere.
    Do you also know where the car was tuned?
    CFLip2x 2012 WRB WRX Build
    Apr 2014
    Flagstaff, AZ
    Quote Originally Posted by cflip2x View Post
    SPT Exhaust,
    Catless Downpipe
    Hella Horns
    When driving the car it seems to be a significantly shorter shift then my last car (2001 bmw 330ci). Not sure if that's just a normal Sti thing compared to my car. No idea on the bushings.
    Sorry noob question but what is a wide band?
    Apr 2014
    Flagstaff, AZ
    So when you say "Man this thing has been beat to hell and back" is that because of the damage to the vehicle, the high octane requirement on the tune, both or something else you are seeing in the pictures (ie. discoloration on parts)?
    Jan 2012
    New Jersey
    Wideband measures air fuel ratios
    with the amount of mods on the car its good to have it monitored your down pipe may have an extra hole for a sensor to be plugged into it but if not your shop could weld one on
    Sent from my SCH-I545 using Tapatalk
    Apr 2014
    Flagstaff, AZ
    Quote Originally Posted by sky_night View Post
    Ignore my question about wideband. Did some research and now know what you are talking about. Do you have any recommendations on what brand of gauges?
    Apr 2014
    Flagstaff, AZ
    cflip2x,
    Any recommendations on if it's worthwhile to do that short block built engine?
    I ask because the shop right now is telling me that I can push 350HP with 91 octane and ~380HP with 110 octane (just a little shy of 400HP). If I'm only going to get reliability out of the car up to ~400HP not sure the $6,000-$7,000 investment is worthwhile.
    Jan 2012
    New Jersey
    Personally I would save my money and see how the car runs for now. You have a decent set up but since the car was in an accident I would like to have some extra money on hand for incidentals that may come up.
    I am not sure how much you drive a day but 400hp is a lot for a daily driver and not sure you would use it all the time. You may want to read this as well http://forums.nasioc.com/forums/show....php?t=1393580
    As for gauges a lot of people like the Defi and AEM gauges. I have the SMY cluster and prosport whiteline gauges.
    Maybe get the SMY Performance SMY / AEM Boost / AEM Wideband (Uego) - Combo Deals - 2008-2014 STI
    Also if you haven't done so introduce yourself to the new members area since more people will see and can also give you some suggestions.
    Apr 2014
    Flagstaff, AZ
    I am not sure how much you drive a day but 400hp is a lot for a daily driver and not sure you would use it all the time. You may want to read this as well Public Service Announcement. "I want 400whp!" Are you sure? - NASIOC
    I actually work from home so don't do a ton of daily driving (or don't have anything that requires me to). I have been going back and forth about keeping my 2001 BMW 330ci as my daily driver and using the Sti only on the track. From what you have said and what I read in the article that sounds like it might be the smartest move for a couple reasons:
    1.) Even in the short time I drove the car (it's been in the shop constantly since I got it, can't wait to get it back from the tuners) I found it kind of rough to just drive around 35MPH roads.
    2.) With the aftermarket turbo it sounds like I may need to worry about blowing up my engine (so in the end getting a short block replacement may eventually be in my future either way).
    Do you think if I only run it with the 91 octane at 350HP that I would still need to worry about blowing up the engine?
    Thanks for the information on the gauges I will need to look into that sooner than later. The link you sent me looks to be a fairly good price for the AEM gauges.
    Lastly I will make a point to introduce myself to the new members area.
    Thanks for your time and all the good information you provided. Hopefully I wasn't too needy right out the gate
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    A buitl shortblock will never be as reliable as a stock shortblock.
    You MIGHT get 100k miles out of a built block if you're lucky.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Jan 2012
    New Jersey
    If you can find out what size injectors you are running. Its all good. I drove my friends STI and it didnt like to go slow it almost felt like it was going to stall. I actually think he has a similar turbo though is is external waste gate. If you want to take a look at his setup FS (USA,NJ): 2006 Subaru Impreza WRX STi WRB 490 whp – 93 pump - Subaru Impreza WRX STI Forums: IWSTI.com
    Some how he though this would make a good daily driver with a baby in the back but hes selling it now. 350ish sounds ok for stock internals (just me im sure others with more experience can tell you better). If that is a similar turbo maybe sell it and get a smaller one.
    Palmyra, NJ
    Nevermind...didn't see where it already had a turbo on it. My bad. Move along...nothing to see here
    Apr 2014
    Flagstaff, AZ
    I might be able to deal with only getting a little less than 100k out of my motor I'll take the car to the track first and see if there is any good reason to go any further with HP on the car. In all honesty the amount of HP now is quite a bit more than my BMW and it's AWD so I may be happy as it is. I would prefer to not spend more than I need to. I just feel it's a waste to have a better turbo and not take advantage of it. I know someone suggested selling it but I'm not mechanically inclined enough to remove and add back the other one so I think in the end I would lose money in that deal
    Jan 2012
    New Jersey
    Well if you were to have the turbo swapped it would need a tune so you would probably have your local shop do it. But again drive the car around see how you like it. If your not used to driving a car with a good amount of power it could be dangerous
