FMS FMIC Install Questions
Results 1 to 2 of 2
This is a discussion on FMS FMIC Install Questions within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Hey people. I bought a FMS FMIC and will be installing it soon. I've been researching DIY threads and there ...
    Registered User boone1186's Avatar
    Dec 2011
    Minnesota
    Hey people. I bought a FMS FMIC and will be installing it soon. I've been researching DIY threads and there isn't any on the web for this particular setup. I hate running into unexpected stuff so figured I'd inquire with the community to see if anyone has any insight on issues that might arise. All I've seen so far is: the crash beam pre-drilled holes don't perfectly line up with the mounts on the core. Also the bumper needs to be modified to fit over the core. Lastly the driver side fender well (plastic) needs to be cut/modified to fit tubing. Anything else anyone can add would be appreciated! Thanks in advance.
    2010 WRB WRX
    Mar 2012
    Sacramento
    I wish you luck ! I did mine and it really got crazy towards the end. You are going to want to buy a throttle body hose cause the stock one sucks and depending how everything fits the stock design might not line up right. Also your intake the pipe goes right where most aftermarket cold air intakes sit so you need one that is really short or extra long.
