Tune required with pre cat back exhaust?
Results 1 to 5 of 5
This is a discussion on Tune required with pre cat back exhaust? within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Want to know if I need a tune if I go from the 2 bolt flange after the pre cat(thereby ...
    Registered User 100plus2Vegas's Avatar
    Mar 2014
    Oceanside,Ca
    Want to know if I need a tune if I go from the 2 bolt flange after the pre cat(thereby eliminating the 2nd cat).
    14 sedan: Protune: 318AWHP 344ft lbs up pipe, Tial EWG, AEM intake, Cobb AP V3, 3" TBE, Avo FMIC, Turbo Smart bpv, Aem air fuel gauge,Cobb knob,Perrin Pitch Stop mount, SPT front strut tower brace, K-Sport coilovers@1.5" drop. Eibach sways, Perrin Spherical end links, Cusco subframe brace, White Line sway braces, Perrin sub frame bushings.
    07 Duramax LBZ- 26psi,intake, TBE, Diablosport programmer, Edge Insight with EGT, EGR block off, BD exhaust manifold, PPE fuel valve.
    STinfection WRX-maniac's Avatar
    Sep 2013
    Western Maryland
    Not sure exactly what part of the exhaust you talking about here. You can run a full cat-back, from the stock downpipe back without a tune. If you replace your stock downpipe with an aftermarket one, you WILL need a tune.
    Stink-Eye Mob #301
    2012 WRB STi Limited Sedan
    2011 WRB WRX hatchback---Retired and traded.
    http://www.clubwrx.net/forums/builds...sti-build.html <---- My STi build thread
    http://www.clubwrx.net/forums/builds...ld-thread.html <----My WRX build thread
    Palmyra, NJ
    I see what you're saying...the stock downpipe is technically a 2 piece downpipe, with two cats in it.
    OP: what you'd need in order to do that (which I don't know why you'd do that anyway...) is a fully custom exhaust built by a custom shop. But considering you aren't eliminating the restrictive first cat, you'll still have a hindrance in performance.
    There's a reason why zero aftermarket companies manufacture just the second half of the downpipe...because it's pointless. To see gains, you need to replace the whole downpipe. And to do that safely and correctly, you DO need a tune for the aftermarket downpipe.
    Just get a downpipe and figure out a tune and go from there.
  5. #4
    Registered User xFalleNx's Avatar
    Nov 2010
    Voorhees, NJ
    +1 to what Mikie said ^
    --Anthony 2011 DGM WRX stg2+sf intake WTFtuned ¯\_(ツ)_/¯
    Official Subie owner as of 01/10/11
    Stink Eye Mob #87
    Bye bye Bimmer
    Hellooo '11 REX
  6. #5
    Mar 2014
    Oceanside,Ca
    Reason I ask is I'm not ready to buy an access port to tune for an aftermarket down pipe and intake.
    I work at a muffler shop and can make my own exhaust all day. I am merely asking if I can go from the 2 bolt flange after the pre cat(eliminating the 2nd cat) without a tune. Thanks for the help.
