Safe Mods, Longevity, Performance - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
This is a discussion on Safe Mods, Longevity, Performance within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Originally Posted by mycologist On the older cars, the only hoses that would make a worthwhile difference performance wise on ...
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    On the older cars, the only hoses that would make a worthwhile difference performance wise on an otherwise stock to stage II car were the intercooler hoses. I don't know if that carries over to the '13.
    To add to your statements, I'd say the turbo inlet is worth replacing with an aftermarket version if the stock one cracks (as it's prone to do). The newer cars are also prone to intercooler cracking at Stage II (and sometimes even stage 1). For the 3G cars, I would reserve a budget for a new TMIC and retune with any stage II modification, unless the OP decides to replace it along with the downpipe.
    2007 Outback 3.0R wagon
    I've thought about this a bit.
    You could do nothing at all and expect the car to last at least 200K miles with proper maintenance according to the schedule. If it doesn't, you could consider never buying another Subaru (I certainly wouldn't).
    Or, you could switch to a larger radiator, larger oil sump, silicone hoses for air and water, and strip the chassis down to metal so that you can seam weld under argon along every spot weld. You could then expect the car to last 200K miles with proper maintenance according to the schedule. If it doesn't, you could consider buying another Subaru (I would).
    Your call. If you need higher cooling capacity there is Koyo and others that make interesting Al radiators (see other threads). I'd not mess with the oil sump if the pickup still works (yours does, you'd know otherwise) and I'd go from there.
    Registered User magasiev13's Avatar
    Dec 2013
    Centennial, CO
    Is DP, CAI, and AP v2-3 all I need to go Stage II?
  6. #19
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Cobb map notes call for a turboback exhaust and an accessport with a stage 2 tune. You could go opensource tune (tactrix cable and laptop) and just get a downpipe.
  7. #20
    Map + downpipe is much more direct, less costly, and should give you the results you want. Shop for a map. Cobb is only one option. There are others.
  8. #21
    Dec 2013
    Centennial, CO
    Single time tune costs almost as much as a AP
  9. #22
    Jul 2012
    Rocky Top
    Right, a top dollar pro tune on a dyno would be a bout $500. But the AP is only hardware, if you want a good tune personalized for your car then you have to shell out more on top of that; and by then you've limited your options as far as tuners because not everyone tunes using an AP.
    But that's not what SD is saying. TurboXS, TorquedPerformance, Vishnu and many others make maps, or you can get a good email tune from WTF tuning or from Phatbotti tuning, or one of many other excellent email tuners from around the country for about $250. Borrow a tactrix cable from someone in your local subaru club to load the map and record some logs, or buy one used for about $150. There's tons and tons of options out there.
  10. #23
    Oct 2010
    Portland, OR
    Quote Originally Posted by magasiev13 View Post
    But unlike the Cobb OTS maps, it would be custom-tailored to your car, and you'd have direct contact with a local tuner should issues arise later.
  11. #24
    Dec 2013
    Centennial, CO
    Quote Originally Posted by Rambo View Post
    I guess that answered my whole question lol. thanks
  12. #25
    Supporting Member livid_wrx's Avatar
    Mar 2014
    South East Michigan
    GREAT thread. I learned A LOT. Thanks guys.
    @Rambo, I've seen you around here and you seem to have a lot of knowledge. I'm looking into buying a project bug eye in late spring and only recently bought my first Subaru so I'm not really experienced with their set up (Former Honda guy, last winter and my Saabaru 9-2x converted me lol) wondering if I could pm you questions when setting up my build?
    Sent from my SCH-I535 using Tapatalk
  13. #26
    Jul 2012
    Rocky Top
    Shifting Lanes, Zax, and EJ257 would be some good people to PM as well.
  14. #27
    Mar 2014
    South East Michigan
    Quote Originally Posted by wreckingball man View Post
    Yep, seen them around too. So much info on this site it's crazy!
