Stage 2 on 2004 WRX - Page 2
Results 16 to 30 of 41
This is a discussion on Stage 2 on 2004 WRX within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; Just go to radioshack get a 2.2ohm resistor and follow the steps in that thread I linked you....
    Registered User frenziedcage's Avatar
    May 2012
    Colorado
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Catless up pipe is highly recommended for your year car as the cat degrades and if it comes apart it will get sucked into your engine.
    sucked into the into the turbo compressor
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by Jake2004 View Post
    The problem with this solution is that my current downpipe will not pass inspection...
    where are you located?
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  6. #19
    Registered User Jake2004's Avatar
    Mar 2011
    Quote Originally Posted by frenziedcage View Post
    The resistor is a very easy mod to install takes 5 mins out of your day I'm not sure about the AP but I know if you get a protune the tuner will erase the CEL for you. You might as well just do the resistor mod simple to do and works great. You could look around on the forums for a used stock dp cuz I know for a fact that you probably wont pass emissions with a hiflow cat. That's the main reason I went catless no reason to spend the extra 200$ on a hi flow catted dp when it wont do what it claims.
    That's a good point. I have a friend that works at Subaru here in PA and he is going to check and see if a HF pipe would most likely pass or fail. This is so dumb since the county next to me doesn't care if you pass emissions.
    That awkward moment when you realize that an energy drink company has a better space program than your country...
  7. #20
    May 2012
    Colorado
    Yes I know where I live personally I cannot pass emission I live in Colorado and they do a sniffer test here. Some people can pass emissions with a hi flow cat I know I cannot tho.
  8. #21
    Mar 2011
    What pipe is on your car now? I assume that ability to pass the test would depend on the pipe and the construction of the cat.
  9. #22
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Whoopsy Craig.... unless the motor is running backward right?
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  10. #23
    Mar 2011
    I am located in York County in PA.
  11. #24
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    LOL I know...I don't know what I was thinking
  12. #25
    Nov 2006
    Denver Metro Area
    here's your specific emissions requirements:
    4
    EMISSIONS INSPECTION CHANGES
    - NEW AREAS -
    South Central Region
    (Berks, Cumberland, Dauphin,
    Lancaster, Lebanon, Lehigh,
    Northampton and York counties)
    When will the South Central Region be re
    quired to begin an emissions inspection
    program?
    Emissions inspections in the South Centra
    l Region will be phased in according to the
    following schedule:
    December 2003...Cumberland, Dauphin
    January 2004...Berks,
    Lehigh, Northampton
    February 2004...Lancaster, Lebanon, York
    What type of emissions inspection will be
    required in the South Central Region?
    Beginning in December 2003:
    Most 1996 and newer model-year vehicles
    will be required to have an OBD I/M
    Check and a Gas Cap Test performed annually.
    Most 1975-1995 model-year vehicles wi
    ll be required to have a Gas Cap Test
    and a Visual Anti-Tampering Check performed annually.
    So, you just need to fix the OBDII code, and make sure you have a gascap, and you're good!
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  13. #26
    Mar 2011
    Sinister:
    I actually just looked up the same information that you did! I found that they only do the onboard diagnostics and gas cap...I was told before that they sniff the car too. Guess that was a load of crap. I appreciate you looking that up for me!
    In regards to the catless up pipe...does anyone have any suggestions for a good one? Would it be worth it to just hollow out the stock one?
  14. #27
    Nov 2006
    Denver Metro Area
    Good stuff dude!
    Personally I only recommend the grimmspeed up pipe.
    I don't recommend gutting the old one for 3 reasons.
    First, if you don't get everything out... Something can break loose and hit the turbo. Then bye bye turbo.
    Second: if you damage the pipe, you might develop an exhaust leak later.
    Third, and the most important. It is dangerous to your health.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  15. #28
    Mar 2011
    Good stuff dude!
    All very good points. I guess when I am looking to spend the money on the down pipe and the AP...another $200 is well worth it. Especially if it will prevent me from having to replace the turbo. With my luck I would spend the money and not get the up pipe and 200 miles after I installed everything else...the turbo would go.
  16. #29
    Nov 2006
    Denver Metro Area
    Exactly my sentiments
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  17. #30
    Mar 2011
    Thanks Sinister!
