Need Help ASAP
Results 1 to 6 of 6
This is a discussion on Need Help ASAP within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I bought a 04 wrx wagon with 147,000 miles with a "suppose to be" boost leak. Well after doing a ...
    Registered User toy4life's Avatar
    Feb 2014
    Riverview
    Unhappy Need Help ASAP
    I bought a 04 wrx wagon with 147,000 miles with a "suppose to be" boost leak. Well after doing a boost leak and not finding nothing we did a compression test which all came back fine except cylinder #4 it showed 0 psi. Which i find strange because even if i have bad rings or piston it should register something. My question to you guys is; can it be a valve problem? Maybe shims or something?
    Please help me before i spends mayor money on an engine.
    Thanks
    Do a leak down test.
    Feb 2014
    Riverview
    Sorry to ask a dumb question but how do i do that?
    Moderator Donkey's Avatar
    Da boonies,Va
    Yup exactly
    2002 FORESTER S
    1998 FORESTER S
    Need Help ASAP
    A leak down test compresses a cylinder to see if pressure is lost and if so, from where. You'll need a fitting and you'll pull the plugs, then find TDC.
    Search for videos, it's a popular test.
    If your 0 PSI cylinder somehow doesn't leak, suspect a valve control problem. If you hear leak in exhaust, suspect exhaust valves or if you hear it from the intake suspect intake valves. You don't care either way in the sense that the head will come off anyway but at least you'll get an idea. Whereas to diagnose rings either confirm leakage via PCV and/or, squirt oil into the cyl and then see if compression goes up.
    All this is easier to see than read about though, sorry. It's a start though.
    Feb 2014
    Riverview
    Thanks man for all the info.
