Turbosmart dual bov on 2011 wrx
Results 1 to 13 of 13
This is a discussion on Turbosmart dual bov on 2011 wrx within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; I need some help on my bov set up put it on soft where rubber ring is and got some ...
    Registered User Z31_2011's Avatar
    Oct 2013
    Monticello, Kentucky, United States
    I need some help on my bov set up put it on soft where rubber ring is and got some back firing and tight it little more and still geting some and I don't have it vented and getting a flutter
    Moderator Donkey's Avatar
    Da boonies,Va
    What?
    2002 FORESTER S
    1998 FORESTER S
    Oct 2013
    Getting flutter sound from intake and backfiring
    Oct 2013
    Installed turbosmart value and having promblems
    I installed the dual port bov on my 2011 wrx and all I get is turbo flutter and check and see vaule is opening why some one is hiting the gas and vaule isn't moving at all
    Registered User Fender137's Avatar
    Jun 2013
    Did you adjust/install the valve correctly?
    Technical Articles | Adjusting Your Bov Or Bpv 1 | Turbosmart USA
    Oct 2013
    Yes the vaule isn't moving at all all u do is bolt it on and hook your vac line and hose up
    Jun 2013
    did you buy the valve new or used? Can you push the piston valve open? You may need to oil/clean the BOV/BPV
    https://www.youtube.com/watch?v=tQj1ExgLzXU
    Oct 2013
    Bought it off ebay supposed been new
    Oct 2013
    Pushed it out was hard get out but now feels like it's free up
    Jun 2013
    Probably could use a clean and some oil
    Oct 2013
    U think need try put it back on and see what type oil need put on it
    Jun 2013
    I would Watch the video and use what Turbosmart recommends to use for their Valves. You can try putting it back on and see how it goes, but why risk it though? It may just get stuck later down the road wall your away from home. (Just a Possible scenario) Like Turbosmart said, they recommend to clean and oil the valve every 6 months.
    Oct 2013
    How can u find type of oil and lub too put on it
