Eg207 heads with 257 block
Results 1 to 8 of 8
This is a discussion on Eg207 heads with 257 block within the Engine Modifications forums, part of the Tech & Modifying & General Repairs category; What problems I'll have with using Wrx heads on a nitrate crank 257 block? It's in a Wrx 02 bugeye ...
    Oct 2013
    Sent from my GT-P3110 using Tapatalk
    Moderator Donkey's Avatar
    Da boonies,Va
    Using JDM EJ207 heads will change the compression ratio.
    2002 FORESTER S
    1998 FORESTER S
    Oct 2013
    Compression ratio will be changed. Cosmetic gasket. Arp studs.
    Problems?
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by soundboy View Post
    Problems?
    That can work. The general consensus is you'd be better off having the combustion chambers worked over to lower compression rather than running a thick gasket. The detonation threshold would be lower, and the OEM gasket seals better.
    Oct 2013
    How's the Best way to lower it?
    Different pistons?
            MainFrame's Avatar
    Austin, TX
    Different pistons?
    Opening up the the combustion chambers, in the heads. Either have them cc matched to the 2.5L heads, or at least have edges taken off where they will have a tendency to hot spot.. if you're wanting to run higher compression.
    What kind of fuel do you plan on using?
    Oct 2013
    Port and polish then?
    92 or 95 octain.
    I'm not in the us.
    I have access to wstermeth. Planning on using the aem v2 kit
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    You'd be better off working a set of EJ257 heads
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
